resistor identification
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Please help me, I have this circuit board with a burnt resistor. There are no complete schematics available, I only found blurry photos on the web, and I have doubts about the colors.
  • iusar
    • Mar 2017
    • 35
    • Hasgard
    Re: resistor identification
    100 ohm 1%
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • GottaBeGrim
      PNY RTX 3060 12GB single fan resistor identification
      by GottaBeGrim
      hello, i have the gpu in the title and a resistor fell off that i need help finding the resistance of. does anyone have the schematic or the resistance value? see images below for the one missing....
      01-02-2025, 08:11 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • redbaron1007
      Klein MM400 resistor identification
      by redbaron1007
      I managed to blow the fuses in my Klein MM400 multimeter and when I replaced them I was still getting a cal and error0 message. I started looking around the board and found one resistor that was testing OL and has a visible burn mark on the top of it so I can't tell what the value is anymore. Its marked as R19 on the board and I included a picture below of what it looks like.
      Does anyone know from working on these what the value is or have this exact meter they could open up and check the value? It's not my only meter, but it is my first real non harbor freight meter...
      07-24-2024, 03:53 PM
