Any kind of IC programmer
  • harp
    • Jun 2022
    • 596
    • Planet Earth
    I recently watched a video, which claims the possibility of programming different types of chips with arduino - just unsolder the atmega328p and connect to the rx and tx pins is a summary...
    https://www.youtube.com/watch?v=6yJ4GbJH_TU
    however, there are universal programmers that supposedly can program many chips, even over 100000+ are listed...
    https://www.advin.com/universal-prog...list-6100N.htm
    Since they all work automatically through the software, the interior of the programmer is very complex, but it indicates that many chips can be programmed according to the same principle only by adjusting certain settings, eg voltage, frequency, additional signals, pin layout, etc.
    for the needs of DIY and occasional programming, it is not at all important that the device is automatic, but that it can program what is needed, whether it is 27xxx... 25xx, 24xx, 93xxx, 95xx, kbxxx various sio startup ic, at..., pic. .. smbus, uart, 1.8v, - 24v, etc... so one thing for all without additional adapters with electronics.
    my question is, is there already any such project for DIY self-builders that has been developed, tested, supported and reliable?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8687
    Re: Any kind of IC programmer
    the adapters are mainly because the pinouts of each of the ICs are different, and then the rest of it is in software.
    The reason why universal programmers can be expensive is because they can control each pin as needed for any chip -- these are actually quite complex to be fast...and safe. The easy way out is adapters which has the added benefit to sellers as they can sell each as an added cost.
    For the DIY and occasional programming most likely you have to deal with the individual pinout. A programmer that's tailored to one specific kind of chip is much easier to design/make.
    Still doesn't make sense what you want to give up for cost. Seems you still want universal programming for any IC and you don't want custom adapters or electronics, but you have to give up something to get price to go down.
    • harp
      • Jun 2022
      • 596
      • Planet Earth
      it's completely fine that what I'm writing makes no sense - I don't have enough knowledge about this topic, but I want to get some information through the discussion and maybe give an idea to someone who has the knowledge and the ability to create a new generation of DIY programmers.
      as for the signals on the pins and the waveforms, I don't know anything about it at all and I wouldn't pay attention to that at the moment. I think that for most protocols, 8 separately controlled channels, such as cheaper DIY microcontrollers or arduino uno, nano... along with power lines, are quite enough.
      but, I think that the design itself can be improved a lot, to get a much more flexible device with which any desired chip can be programmed. my basic assumption is that if the datasheet of the chip is publicly available and if the chip is intended to be read/programmed, then there must be a way to do it without constantly buying various adapters that always fail... always needs some "specific" you dont own...
      for example, changing the clock frequency and timing would should be adjustable via programmer software, while the voltage could be adjusted by hardware - from 5v from the usb connector to any voltage using 34063, 1117 and similar.
      My original idea is that the software interface enables you to input of new data from the datasheet in order to create new conditions for communication on each channel. and it should be made as simple as possible, clear and intuitive as possible for all important parameters.
      therefore, there would not be a list of thousands of supported chips, but only groupings, categories that include the same characteristics.
      eg if the i2c protocol is created, then it doesn't matter if any chip from the 24xx series is programmed or accessing the temperature sensor or the BQ eprom of the battery.
      if an individual chip requires an additional signal in addition to the i2c protocol, it can easily be included on a free channel, as well as changing that i2c protocol as needed.
      I see the different layout of the legs as the smallest problem. first you need to come up with a basic "bare bone" model that will not change, and that can be easily modified or add an adapter as needed. here's how I imagine it right now in attach.
      • harp
        • Jun 2022
        • 596
        • Planet Earth
        I've found this interesting project, so look
        https://www.instructables.com/DIY-UN...VR-PROGRAMMER/
        It is based on PIC18F2550 and connect with usb to pc.
        Supported devices:
        PIC Devices :
        PIC 10-12-16-18-24, dsPIC 30-33
        3.3V devices : PIC12F1xxx, 16F1xxx,18FxxJxx, 18FxxKxx, 24Fxxxx, 24Hxxx, dsPIC33xxx.
        AVR Device :
        It supports serial and HV serial programming.
        AT90Sxxxx, ATmega- 48, 8, 88, 8515, 8535, 16, 164, 168, 32, 324, 328, 64, 644, 1284.
        ATtiny- 11, 12, 13, 313, 24, 25, 26, 261, 4313, 44, 45, 461, 48, 84, 85, 88, 861.
        EEPROM Device :
        24xxxx, 25xxx, 93xx6, DS24xx, 11xxx.
        I found another one, PonyProg, which comunicate with pc over serial RS232 cable, but covered a very much adapters...Its purpose is reading and writing every serial device. At the moment it supports I2C Bus, Microwire, SPI eeprom, the Atmel AVR and Microchip PIC micro.
        All are DIY programmers, and good base for developer
          • 30956
          forget it,
          for anything not serial your gonna need 22-42 pindriver circuits and your not gonna find decent software to run it anyway.
          best bargains are the XGecu units, if you dont need more than 40pins then T48 and if like me you get 42pin roms then T56
          and software updates are regular with new devices.
          https://www.aliexpress.com/item/1005004419266579.html
          https://www.aliexpress.com/item/4000802208288.html
          to get better than that your looking at 600+ for something like a UXP48, and even they arent great because they charge for software updates! (bastards)
          • CapLeaker
            Leaking Member
            • 8056
            Yeah, the XGECU T48 or T56 are easy, cheap and they work. I use an older TL866II.
              • 30956
              i just sold my 866II to put the money towards a T56,
              i got almost what i paid for it because the buyer needed it fast.
              • CapLeaker
                Leaking Member
                • 8056
                Nice upgrade! I thought about upgrading too, but then on a second thought I don’t need it to program anything that I could not program already. I’ve got the TL866II and the RT809H. I guess, I am good for now.
                  • 30956
                  it's great until your programming 48pin tsops with a stack of adapters or 42pin eproms with manual bankswitching!
                  • harp
                    • Jun 2022
                    • 596
                    • Planet Earth
                    In this mentioned programmers tl866, rt809, t48, t56... or others, is there a option to make or add manually to list some config/setup file with custom timing for specific signal, not binary, some human readable?
                      • 30956
                      not sure, but you can run the software in demo mode - try it
                      http://forums.xgecu.com/viewthread.php?tid=20
                      • H34TO
                        ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                        by H34TO
                        Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                        06-17-2025, 07:17 AM
                      • ugamazing
                        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                        by ugamazing
                        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                        08-31-2022, 07:34 AM
                        by SMDFlea
                        Bad...
                        09-02-2021, 04:40 PM
                      • irfan karatela
                        Programming XMC 25QH256C with a CH341a programmer
                        by irfan karatela
                        I'm able to read and write the chip by selecting a winbond IC of the same size, but when verifying it fails at around 25 percent.
                        I've modded the ch341a to 3.3v.
                        Can I update the database to include the XMC 25QH256C?
                        02-17-2025, 01:54 PM
                      • urad29
                        BIOS Programming - Which programmer to use??
                        by urad29
                        I have done quite a lot of research into which programmer to use and despite me thinking that there should be quite a lot of documentation on this subject there is relatively little.
                        I am looking for a programmer for laptop EC chips (SMD and BGA).
                        I do have some knowledge in programming as I have used the CH341a for BIOS chips.
                        I am looking into the RT809H or F.
                        Despite there being a list of which chips the RT809 supports, it seems that there are videos of people using it for chips not on that list.
                        I guess I would like a programmer that can program...
                        08-10-2023, 03:53 AM
