Proprietary battery pack
  • Hondaman
    • Sep 2008
    • 1079
    I hate to ask this question, because there is no easy answer. Basically, I have a proprietary battery pack. 3 AA batteries sitting on top of 4 AA batteries, glued together. I need a "tab welder" to reproduce this. But I don't really know what settings I would use.
    Basically, it is the battery pack from a Scientology E-Meter ("John Travolta Space Cootie Detector"). I got it for journalistic, research and hilarity purposes. Only about 40,000 of these units were made ("Quantum Mark 7") so I suggest a new old stock exact match is out of the question.
    I found a couple of 8.4V battery packs online that really might work (3 cells on top of 4 cells). But they are lithium-ion. Will the battery charging circuit inside the meter be able to handle the different chemistry / capacity?
    I apologize that I can't give any real info about the charging circuit, except it takes a 5-volt barrel plug from a "wall-wart" AC adapter plugged into the back of the space cootie detector. Any thoughts?
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Proprietary battery pack
    replace with single tabbed cells . they solder in .
    https://www.cs.cmu.edu/~dst/Secrets/...intenance.html
    https://www.cs.cmu.edu/~dst/Secrets/E-Meter/Mark-VII/
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      is the pack simply 7S or is it tapping different voltages from it?
      I suppose if you have protected li-ion packs and it's simply 7S with no taps, you could just do 2S protected lithium ion. The protection on the li-ion hopefully will prevent the incompatible ni-cad charger from making the li-ion explode.
      • Hondaman
        • Sep 2008
        • 1079
        I'm seeing some NiMH AAA battery packs online in the "hump" configuration (3 cells on top of 4) (might be the same battery as the Snap-On MTG-2500 scanner for diagnosing your modern car's sophisticated electronics). The battery has a thermostatic switch inside the cells that cut off power (presumably for both charging AND discharging) at 55 degrees Celsius. Is this the kind of protection I need?
        The NiMH cells are around 750 mAh or 800 mAh, very close to the Ni-Cd I took out. Is the meter's internal charger really not compatible with NiMH?
        BTW: Older E-meters power some of the meter with 6 cells and part of the circuitry uses all 7. I have a later design -- Only two wires come out of the battery shrink-wrap, so I presume all of the meter uses all 7 cells.
        Will this battery type be a problem for this charger? Do let me know.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I suspect the 7S configuration (make sure you don't have any taps in the pack!) is used when the circuit was designed for a PP3 battery and then found out it doesn't last long enough...
          The comment is to indicate that the internal charger is incompatible with lithium ion. If you're replacing with nickel batteries, this isn't a concern.
          However NiMH cells use a slightly different charge algorithm than NiCd. In this case it looks like it has a dumb charger so it probably doesn't make a difference.
          • Hondaman
            • Sep 2008
            • 1079
            I got a 7-cell pack online (AAA NiMH batteries) in the "hump" configuration and a standard connector. I found a suitable connector from an old tower computer that I scrapped, and soldered the wires right in. The meter seems to charge and run just fine. As you can see, I'm ready to start auditing the space cooties away. With plenty of the same beverage that the dear leader David Miscavige drinks !
              • 31091
              so it's a glorified lie detector, a galvanic meter?
              • Hondaman
                • Sep 2008
                • 1079
                Yes. It was originally developed by a chiropractor, Volney Mathison. I have no idea why he thought this was appropriate for use in his field. Then when L. Ron Hubbard got into an argument with Mathison, suddenly LRH denounced Mathison's meter and you could only use LRH's meter, which (like everything else in Scientology) is rigged to give maximum financial gain to the organization.
                • brispuss
                  Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                  by brispuss
                  Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                  Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                  I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                  12-28-2022, 02:58 AM
                • razenxd
                  How can I charge that battery pack?
                  by razenxd
                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                  Now, I have noticed a few things.
                  The "dead" battery, while connected to charger and NOT Charging will...
                  12-05-2024, 06:11 AM
                  Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
                  by sam_sam_sam
                  I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
                  So I have put them on the battery testing machine to drain each battery cell down to...
                  09-04-2022, 04:45 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                  by sam_sam_sam
                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                  I bought this from an eBay seller but unfortunately they only had one
                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                  I bought three of from them to also make battery packs with this output power limit in mind
                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                  04-23-2025, 05:50 AM
