Removing coke or sugar syrup from liquid damaged devices.
  • rotceh_dnih
    • Jun 2020
    • 43
    Got an Xbox that had coke spilt in it, must not have been there long but it was sticky and my normal solvents were not making it budge so on a time budget I hit it with some Ajax spray and wipe glass cleaner and it brushed off within 20 seconds.
    Whatever's in that bottle is some nasty stuff but it worked a treat!
    P.S. I gave it ISO bath, ultrasonic then ISO bath again after these photos as I thought if it cleans up that well so fast it would very likely corrode if anything was left on the PCB.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Removing coke or sugar syrup from liquid damaged devices.
    I had an old PC motherboard that likewise had cola spilled on it, it came right off with ... plain water, no solvents needed. I suppose it depends on the brand of soda, but sorry I don't know what soda it was.
    • CapLeaker
      Leaking Member
      • 8288
      Just wanted to say… a mixture between warm water and a little bit of Dawn dish detergent does the same thing. I even tried that combined with my ultrasonic cleaner and the heater on 60C and shit comes out like new! No scrubbing and IPA bath required!
        • 31151
        yea, it's a water based beverage so treat it like washing the dishes.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I think those "orange" sodas are the ones that may need a small amount of soap but pure water should be able to clean that off too.
          However... coffee on the other hand...
            • 31151
            coffee contains oils - you need soap for that
            • redwire
              • 3912
              Once you have the chemistry figured out (contamination is water or oil based, acid or alkaline) I find a good long soak helps with thick deposits, 5-15 minutes.
              I usually use hot water and a little dishsoap, a long soak and then the toothbrush scrub and then a rinse and dryoff or air blast.
              I used to fix liquor dispensors, the ones that dispense shots and mix at a bar. It was pretty gross, syrup all over and on the floor, when you go out back to the tank room. One mistake and you get sprayed, like when replacing a solenoid.
              I regularly dump coffee on my PC keyboard, CMStorm Cherry switches and I'll just unplug it fast and toss it in the bathtub for a rinse. It has survived many times so far.
              edit: Australia is lucky Ajax Spray n' Wipe Triple Action Glass Cleaner is loaded with good stuff. Here I can't buy a decent glass cleaner Windex is crap.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                When removing residue from price stickers and sticker labels my go-to's are rubbing alcohol or Windex. One or the other almost always works. WRT water, distilled water might be better as a solvent than tap water, since distillation reduces dissolved impurities.
                PeteS in CA
                • redwire
                  • 3912
                  I find no need for purified water if you blast off the beads with a shake or compressed air, there is no visible residue. Factory boards come with more flux residue. Although compressed air does generate static electricity if you go crazy with it. Hard part is drying water under a BGA. Sometimes I'll toss a board in an oven or let it air dry for days.
                  Household cleaning product formulation varies by nation, so a "brand name" is not always solid.
                  I think Windex sucks because it streaks on my car window after cleaning three times, so I'll never use it again. The perfume, colouring agents or apparently some paper towels have added moisture absorbing chemicals added which is what actually causes the streaking. For windows, I've used Bon Ami (good) and now use Invisible Glass which contains a little acetone. But some regions it's IPA.
                  Nothing works for me with sticker adhesives. IPA doesn't do a thing.
                    • 31151
                    most window cleaner is just water and vinegar mix.
                    • harp
                      • Jun 2022
                      • 616
                      • Planet Earth
                      When you have clean sticky/sugar liquid from the pcb:
                      1. soak in water, then brush
                      water mix and dissolve sugar and salt, alcohol (ipa) does not
                      Water is solvent in this case
                      2. rinse with ipa or 96% ethanol
                      alcohol mix and dissolve water in any ratio, so it helps to dry (usefull especialy under bga)
                      3. Hit with compressed air if you can
                      4. Eventuali repeat from 1. till end result is fine
                      If pcb is oil/fat, like butter:
                      1. use adequate detergent (soap) with plenty if live water over it to take it off, scrape it, brush it...
                      2. Rinse vith ipa
                      3 air...
                      • silver60618
                        How to clean Liquid Metal from under CPU?
                        by silver60618
                        Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                        The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                        Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                        07-11-2025, 01:47 PM
                      • Hondaman
                        Liquid cooling?
                        by Hondaman
                        I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                        (After previous generation hardware [Gigabyte] didn't...
                        05-08-2025, 09:37 PM
                      • kurland
                        Strange liquid on damaged GTX1080 card
                        by kurland
                        I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
                        As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
                        Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
                        11-17-2020, 07:14 PM
                      • mitchw
                        MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                        by mitchw
                        Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                        It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                        I quickly took it apart and washed the liquid residue off the mainboard.
                        The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                        The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                        Now the laptop...
                        07-16-2025, 07:55 AM
                      • Jane
                        What liquid to use
                        by Jane
                        I would like to repair faulty backlight in Philips TV. In various videos, guys use a liquid before using a suction tool.
                        Can anyone let me know what kind of the liquid is it? Or what liquid do you use?
                        Thank you
                        Here is a video
                        https://www.youtube.com/watch?v=XzFT-o64jDQ
                        02-15-2024, 05:51 AM
