Can Micro Controller PIC16C72A be read?
  • mitsu2k
    • Aug 2013
    • 219
    The PIC16C72A is an OTP (One Time Programable) microcontroller. I read somewhere that it cannot be read with a debugger tool such as a PICkit 3 or such. Does anyone know if this is true on this model? I looked at the datasheet but couldn't find any information.
    Anyone know for sure?
    • 31139
    Re: Can Micro Controller PIC16C72A be read?
    you can read it if the protect-bit has not been set
    • mitsu2k
      • Aug 2013
      • 219
      Thank you sir!
      • mitsu2k
        • Aug 2013
        • 219
        Hi stj, got a question. I picked up a pickit3 and installed MPLAb X IPE. When I select any one of the OTP PICs such as the PIC16C72, the connect button gets greyed out. If I select something like PIC16F72, the connect button is available. It’s like IPE is not capable of connecting to these controllers or I am missing something. Do you have any ideas?
          • 31139
          i think the pickit3 cant handle the old OTP devices.
          i'v not done pics in years, but i remember keeping the pickit2 for a reason
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            i'v not done pics in years, (...)
            Likewise...
            • mitsu2k
              • Aug 2013
              • 219
              Ok so as it turns out, I need to use a PicStart Plus to communicate with this particular one. Apparently none of the PICkit 1/2/3 will do the job. You would think that they would be backward compatible with older PICs but apparently they are not. Thanks for your input and help stj..
                • 31139
                the TL866-IIplus lists it as supported.
                so does the T48 / TL866-3g and the T56
                • mitsu2k
                  • Aug 2013
                  • 219
                  Cool, I'll look into those. Thank you
                  BTW, does TL866-IIplus use it's own software or will MPLaB work?
                    • 31139
                    it uses this:
                    http://forums.xgecu.com/viewthread.php?tid=20
                    and this is the company
                    https://xgecu.aliexpress.com/store/4805043
