Identifying these resistors
  • Sudsy55
    • Dec 2022
    • 5
    G'day all,
    new here and fairly dumb electronics wise but learning slowly. i have a project i'm working on that has some surface mount resistors that i'm not sure how to identify. one has 222 on it but the middle 2 is underlined and measures 2.1k. The other has 184 with the same underline and this measures 70 something k. These are both still in circuit. Everywhere i've searched i have not found anything relating to an underline when searching for codes. Do any of the gurus on here know what the underline means?
    Cheers
    Bob
  • petehall347
    • Jan 2015
    • 4429
    Re: Identifying these resistors
    last digit is the amount of zeros . so 222 becomes 2200 .or 2.2k .
    • Sudsy55
      • Dec 2022
      • 5
      I know that normally is the case but what does the underline mean. The 222 works that way but the 184 is totally wrong. It should read 180000k but only reads 70ish k. That's what has me confused
      • R_J
        • Jun 2012
        • 9579
        If the resistor is in circuit, then you are measuring parallel resistance. Best to post pictures.
        If all the digits are underlined it can indicate 5% tolerance. It may just be the way a certain manufacture indicates something?
        • Sudsy55
          • Dec 2022
          • 5
          It's only the centre digit that is underlined. They are the only 2 resistors on the board with an underline. All the others are normal 3 digits
          • R_J
            • Jun 2012
            • 9579
            For 0603 ±1% E-24 series, one short bar under
            marking letter
            • Sudsy55
              • Dec 2022
              • 5
              marking letter
              Ok thank you for that. It seems it means it's 1% so i gues if i remove the 184 from circuit and test it will be 180000k.
              Thanks again for the explanation
              Cheers Bob
              • petehall347
                • Jan 2015
                • 4429
                Cheers Bob
                180k
