NTC Thermistor recommendation
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    The NTC thermistor is blown up in a 650W SMPS (The green lentil). I can't see any reference on it.
    The assumption is that it should be a low resistance, because It's the bridge between the diode output and the input from the positive main capacitor.
    Any reference you would recommend to have some at home for this situation? Or shall I put a jumper where It was the NTC?
    Thanks in advance,
    Francesc
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: NTC Thermistor recommendation
    I would not recommend you to put a jumper instead of a thermistor!
    It just doesn’t burn out, you rather have a short circuit in the circuit (diode bridge, mosfet, ...).
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      I know, I now.........I was in ironic mode on.
      What I don't know is which one I should use when the one to be replaced is not readable.
      • R_J
        • 9579
        Make? Model? diameter of ntc, pictures? SCK-054
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          You could put a jumper for "testing purposes"... but my recommendation then would be to do this ONLY if you have an incandescent/halogen bulb in series with the PSU's input / AC line. 200-300 Watt halogen should do well in most cases.
          Otherwise, SCK-054 or SCK-085 or SCK 2R58 could be a good start.
          That said, I have seen some PSUs not use a thermistor, and they weren't cheap no-name units either. The APFC inductor typically doesn't provide enough resistance/impedance as an NTC, but it may be enough in some cases to run the PSU without one.
          • Francesc V.
            Tempus fugit
            • Nov 2022
            • 231
            • Catalonia
            Thank you mates..........I've purchased 3 types between 5mm and 10mm and low resistance.
            • connorcc2005
              Thermistor specs and cross reference
              by connorcc2005
              I'm getting some conflicting information and thought I'd toss it out to all of you for input.
              What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
              The physical diameter of the piece is 5.1mm measured with a caliper.
              Other than what you see in the pic, there is no other writing on the part.
              My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
              06-16-2022, 04:16 PM
            • MMH3
              Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
              by MMH3
              i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
              Never ever i experienced problems with that.
              Now i have one 5050sff machine, where this jumper isnt working at all.
              I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
              The history of the machine is that i used it in my office...
              03-23-2025, 09:28 PM
            • speaktorob
              Reference Nvidia GTX 980 ti - looking for a new shroud
              by speaktorob
              So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
              Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
              03-22-2024, 03:00 AM
            • Use2bavolvo
              Magic chef oven - thermistor ref voltage issue
              by Use2bavolvo
              I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
              Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
              01-19-2023, 01:32 AM
            • nmbb
              Can not find Model/Value of Thermistor.
              by nmbb
              Machine: Autoclave.
              Brand/Model: SANYO MLS-3780
              Manual: (Sorry search option not working on this PDF)
              Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
              06-02-2022, 05:55 PM
