Anyone know this parts?
  • ambetz12
    • Jul 2011
    • 16
    • Philippines
    hello can some identified what part is this i cannot get any schematic for acer z35 lcd screen. thank you
  • Odbileg
    • Apr 2016
    • 3
    • Mongolia
    Re: Anyone know this parts?
    This is Synchronous Step-Down Regulator. Part number: SY8208
    • R_J
      • 9610
      I agree with above
      • lotas
        • Jan 2016
        • 4813
        • Russia
        This is YVxxx - SY8366QNC. https://aliexpress.ru/item/100500134...00015769558204
        https://www.alibaba.com/product-deta...187248197.html
        https://www.ebay.com/itm/403518669814
        • ambetz12
          • Jul 2011
          • 16
          • Philippines
          thank you so much for the reply
          • H H
            3090 FE Part Confirm/Identification
            by H H
            I'm hoping someone could help me confirm if I have identified the following parts correctly.
            Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
            The parts needing replacement are on the back of the board behind the HDMI input.
            I have identified the parts as the following:
            C6037: MLCC 0.1uf/16v(0402)x7R W05
            R6016: RES 499 OHM 1/16W (0402) 1%
            LB10911: Ferrite Bead (0402)...
            02-16-2025, 01:09 PM
          • Mark D
            Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
            by Mark D
            The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
            10-29-2024, 03:15 PM
          • 2elw
            SVOD4 PCB pictures + parts
            by 2elw
            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
            GW1N-UV9UG169C6/I5 FPGA - Its a...
            07-04-2025, 12:23 PM
          • SurrealMustard
            What parts can be salvaged from a plasma with a damaged display panel?
            by SurrealMustard
            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
            03-09-2025, 08:29 PM
          • DynaxSC
            Asus Rog Strix B360-I Gaming - Parts Identification
            by DynaxSC
            I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
            I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
            Thanks in advance...
            08-23-2023, 07:56 AM
