Is it common for these caps to go bad?
  • mitsu2k
    • Aug 2013
    • 219
    Just wondering how common it is for these types of caps to go bad. I have a couple that are measuring approximately correct (997nF) however a couple of them show signs that they have been pretty warm at some point. I'm replacing them anyway but just wanted to know how common it is for these to maybe act up when hot.
    • 31067
    Re: Is it common for these caps to go bad?
    film caps rarely fail unless you put too much current through them.
    • mitsu2k
      • Aug 2013
      • 219
      Good to know. Thank you
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Actually depending on how they are used in the circuit they can fail quite often.
        Sometimes it does not matter (if they are just for EMI purposes).
        Other times it matters allot, if they are used as a capacitive dropper.
        Dave did a video on this, also some interesting comments in the forum thread there on it, video linked in the first post there:
        https://www.eevblog.com/forum/blog/e...acitors-fail!/
        • redwire
          • 3910
          What makes you think your film caps show signs of heating up?
          Normally they don't make much heat, and if seeing high ripple currents they seem to go low value.
          It could be parts nearby that are heating them, or the plastics are deforming due to age.
            • 31067
            the resin goes yellow/brown if they run hot.
            • CapLeaker
              Leaking Member
              • 8196
              I’ve seen them exploded too.
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
