question for an ssr component
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i want to ask the follow
    AQH2223 is an ssr chip
    between 6 & 8 pins i have 53 ohm resistance is shunt ?
    or its logical value ?
    thanks in advance
    • 31139
    Re: question for an ssr component
    that sounds faulty
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Originally posted by Xristakis795
      hi to all
      thanks in advance
      Here's a picture ..
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        the resistance must be high ?
        it doesnt refer the manual the value
          • 31139
          6 & 8 should be almost open-circuit when not turned on.
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            ok very thanks for the answer
            so in my case i have shunt the ssr right ?
              • 31139
              the ssr is bad if you have it desoldered.
              • cind12
                GTX 1080 TI Gigabyte Aorus low resistance on vmem
                by cind12
                Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                Resistance on 12V 4K ohms (Power present when on)
                Resistance on 12V PEX 4K ohms...
                12-08-2023, 09:09 AM
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • Jane
                What is the lowest acceptable resistance on a coil without considering a short on PCB
                by Jane
                I have Asus FA506 ( board DA0BKXMB8D0 Rev: D). Can you please roughly indicate what the lowest resistance I should measure on a coil? I know that a low resistance is allowed on coils in CPU or graphic circuits but can you provide acceptable values of resistance?
                Thank you.
                02-27-2024, 01:42 PM
              • loopster
                645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                by loopster
                Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                My resistance value is 2.2 Ohms, which doesn't look good to me.
                Thanks to everyone willing to give a value.​
                06-05-2025, 02:33 PM
              • CG2
                Janome DC3050 Sewing Machine Pedal Resistance
                by CG2
                OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                04-14-2023, 07:53 AM
