Analog Multimeter Readings
  • redwire
    • Dec 2010
    • 3906
    Re: Analog Multimeter Readings
    Gorgeous and not too expensive in the UK. I reverse engineered one from IBM and it was mostly shift registers and a DC-DC on board, so it wouldn't take any CPU work doing mux scanning.
    VFD's are great even in sunlight with a blue/green filter.
      • 30985
      https://www.ebay.ca/itm/254794673033
      • redwire
        • Dec 2010
        • 3906
        The second board looks like Bally, with a 6-pin header to the Noritake VFD PW-899-101. That might use a Noritake/iTron custom IC controller possibly ISE25001.
        The others are HD44780 compatible but 14-16 pin headers needed to support parallel-mode.
        I'd remove the display and toss the Bally board. Noritake would have datasheets.
        eBay global shipping ripoff makes it crazy expensive. Sigh.
          • 30985
          noritaka wont give data for syncronous interfaces - i tried,
          it's a trade/vendor secret.
          i know enough to use it though.
          (because i have access to the gameboards and a logic analyser)
          that interface looks interesting though - it may be MDB or some extension of ccTalk
          but i did notice that disgusting shipping cost!
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            Originally posted by stj
            the vfd's arent multiplexed, they have onboard microcontrollers that handle ASCII conversion and mapping from a syncronous serial interface.
            That's what i described you would most likely find onboard a VFD.
            A µC scanning (multiplexing) the vfd (most likely thru an IC because voltage levels) and a serial (often 3 wire) interface communication port.
            In more compact designs the µC can multiplex itself the vfd (e.g. https://datasheets.maximintegrated.c...ds/MAX6850.pdf)
            Providing that you can figure out the µC communication instruction set an all onboard vfd will much easier to re-use
              • 30985
              the microcontrollers are more high level than just multiplexing,
              you can set the cursor position and send characters, set brightness, flashing or underline, scroll the line left or right etc.
              it really is a terminal emulator almost.
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                #27
                Yes there are some Notitake datasheets and even some Arduino libraries available. For Noritake VFD PW-899-101 (Noritake Itron GU140X16G-7000 Dot Graphic VFD Display Module) the Arduino library and datasheets for GU128X64-800B as examples.
