PLCC84 package reflow post cleanup question
  • powrslave
    • Jun 2020
    • 6
    • usa
    What is the cleanup process for post reflow on a PLCC84 package?
    I'm worried about left over flux under the chip etc.
    Spray it all out with acetone/alcohol?
    • 30979
    Re: PLCC84 package reflow post cleanup question
    kitchen towel to absorbe/wipe away the isopropanol & flux
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
    • tony359
      Reflow equipment
      by tony359
      Hello all,
      I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
      I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
      Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
      12-25-2021, 01:29 PM
    • evilkitty
      Flux causing high resistance short?
      by evilkitty
      Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
      Temp is on the left humidity is on the right
      i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
      The pin out looking down from the top is (note this is common cathode)...
      07-17-2024, 09:38 AM
      Multifix 425-01 and 450-01 Rework Flux Datasheet
      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
      - No Clean Formulations
      - Low residue
      - Range of activity to deal with different component solderability
      - Halide free
      - Suitable for dispensing
      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
      Both products are supplied in syringes or cartridges for application by dispensing....
      10-07-2024, 06:02 AM
