Airgap in soldering iron tip
  • cook
    Quiet observer
    • May 2010
    • 100
    Some soldering tips do not fit on the heater element very tightly and you end up with an air gap between the tip and the heater core.
    What experiences has anyone had using high temp copper paste or silicone grease to fill the air gap and get better heat conductivity on the tip?
    Did it work well over time?
    Or maybe you used something else to fill the air gap?
  • redwire
    • Dec 2010
    • 3912
    Re: Airgap in soldering iron tip
    I've only seen the airgap issue with Hakko tips for 900 and FX888, whose tips I measured are a few thou smaller ID than 900 series tips. I guess Hakko tried to improve the heat transfer.
    The airgap is there for two reasons - manufacturing tolerances and thermal expansion.
    The thermal expansion coefficient of the ceramic heater compared to a iron/copper tip, it seems to be about half ref. Kyocera. This means the metal (tip) changes size twice as much as the ceramic and I imagine a cold tip should not crush the ceramic, or squeeze out during warm up when the heater is hot but tip cold. You don' want to crack the heater.
    Silicone (based) grease was tried and does not work because it can't take the high temperatures and becomes a huge mess. https://www.mcmaster.com/heat-transfer-paste/
    I wonder if a copper foil wrap would work better?
    • diif
      • Feb 2014
      • 6978
      • England
      I bought a piece of thin copper with the idea to make a thin tube, then I discovered T12 tips and irons, so didn't bother with the upgrade.
      • redwire
        • Dec 2010
        • 3912
        OP could try even aluminium foil. It's better than air for conducting heat.
        Cement has 1/10 the heat transfer, it's largely an insulator so the T12 construction is still not the greatest. Especially with all the cheap chinese tips that contain almost no copper in the core.
        My old Weller is still king for heat, sadly.
          • 31214
          no shortage of copper in my last tip,
          maybe the cement is zinc-loaded.
          so @cook:
          what make/model iron is it??
          most transfer heat from the sides - only weller afaik transfer from the end of the element
          • cook
            Quiet observer
            • May 2010
            • 100
            I have a Yihua 939D. I will be using a genuine Hakko tip on it - T18 BR02
            I also have a RadioShack Pro Line 70W -- similar style iron.
            One post suggested copper paste, an anti-seize compound that can take high heat. I have not tried the paste myself, but I was wondering if anyone had tried it and if it made much difference. Maybe that post was specifically addressing the air-gap in a Weller iron.
              • 31214
              T18 tip is for the 888 iron isnt it?
              the 939 i'm pretty sure is a 900m clone - slightly differrent size iron
              • cook
                Quiet observer
                • May 2010
                • 100
                I believe I may have gotten the wrong Hakko tip. Somehow I thought the T18 was the same as a 900M. But I am seeing now they are slightly different and the T18 is just a tad shorter than a 900M. Is that the only difference? I am hoping that although they are different, I may not really notice the same as long as I am very careful and don't over tighten nut that holds the tip on.
                  • 31214
                  the main difference between the 888 iron and the 900m is the diameter of the element
                  if you try to use 900m tips on an 888 they are slightly loose.
                  so i imagine an 888 tip will be a tight fit - or not fit on a 900m element.
                  • cook
                    Quiet observer
                    • May 2010
                    • 100
                    My Yihua 939D uses the 900M tips, as listed in their documentation that comes with the unit. When I use my 939D to compare the 900M tip with a real Hakko T18 tip, I notice the following 2 differences.
                    1. The hole in the T18 tip is just slightly more narrow than a 900M, but it still easily slides on the ceramic heating element.
                    2. The T18 is about 1mm shorter than a 900M. When you put on the T18 tip, it does not slide all the way down ceramic heater to where it should meet the metal sleeve. I think I will make a small metal spacer to fill the gap so that when I tighten the nut for the element cover, the tip will be pressing small spacer which is pressing on the metal sleeve. Without the spacer the tip would be pressing on the ceramic heater and I don't want to do that for fear of breaking it.
                    Regarding my original question about using copper paste to fill the air gap in the tip, I no longer think I want to do that. The T18 tip does not leave hardly any air gap to worry about.
                      master hoarder
                      • May 2008
                      • 12175
                      I don't know about copper, but I think The_Unique (or someone else here a long time ago) suggested aluminum foil. However, if I remember correctly, there was a warning that once this is done, the tip may get permanently stuck on the heating element. So it may or may not be a good idea, depending on how often you like to change tips.
                      On irons that use 900M tips, I don't usually use anything less than a 3 mm chisel or bevel tip, as even the genuine tips don't have enough thermal mass or good conductivity for heavier joints.
                      Yup, that's the suggestion I've been seeing elsewhere as well.
                      True.
                      But even then, this is still better than a thin layer of air.
                      So I'm thinking perhaps ceramic/clay can be used to fill the gaps, too.
                      On another note, I have built a "clay solder pot" before and it did work:
                      https://www.badcaps.net/forum/showpo...5&postcount=33
                      This was before I got my 75-Watt soldering station, I think. So I was trying all kinds of crazy experiments to make a device that can tackle large solder joints.
                        • 31214
                        if you do intend to use a packing substance, think about how it changes with time or heat.
                        i packed a tip once with arctic-ceramic.
                        when i had to replace that tip i had to use pliers to remove it!!
                        • corrize
                          Quality solder iron tips and Kapton ?
                          by corrize
                          Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
                          I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
                          Do you have brand of qually tips pls ?
                          Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
                          05-24-2021, 11:35 PM
                        • tony359
                          Kaiweets USB soldering iron
                          by tony359
                          I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
                          As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
                          In other words, do you think it's expected and...
                          02-06-2024, 12:51 PM
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
                        • edugimeno
                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                          by edugimeno
                          Hi!!
                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                          At a certain point, moving stuff around, I put all wires back in place and...
                          03-24-2024, 02:31 PM
                          Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook Spin 713 Specification for Upgrade or Repair
                          This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...
                          09-07-2024, 03:10 AM
