Replacing broken pads...
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I know its insane and most of the time i use only jump wires...but sometimes when i see ripped bigger pads from board like from places where you solder bios or ite chip...i would like to make/reconstruct a new pad/pads. And it is not a problem to make it...the problem is how to glue it on board...thats where i am stuck...I tried with several glues and temperature resistance epoxies...but they all fail...when i put my solder pen..thats the end.
    Maybe you have some experience on what glue or silicone to use?
    • 20665
    Re: Replacing broken pads...
    UV solder mask .
    • diif
      • Feb 2014
      • 6978
      • England
      I use this https://www.tme.eu/gb/details/ch-cw2...ronics/cw2500/
        • 30983
        if anybody wants uv solder mask, buy the blue, not green and never red.
        remember the laser/led is closest to blue and cant penetrate the red or green chemical very deeply.
          • 20665
          Thanks for the info, i have the green and it takes ages to dry. Can you recommend a good cheap UV lamp .This is the type i have,its crap https://www.ebay.co.uk/itm/MYLEE-Whi...G/173939501975
            • 30983
            unless it's water-thin it does take a while.
            i have these:
            https://www.aliexpress.com/item/32881835487.html
            https://www.aliexpress.com/item/32971347194.html
            https://www.ebay.co.uk/itm/113847584031
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • foshland
              GTX 980TI with 2 broken pads on memory module
              by foshland
              Hi, I got a 980TI with 2 pads broken under a memory module and yes, they are needed pads, so I just cant ignore them. Ill try to fix them but im waiting for the pads and solder mask to arrive.
              Thinking on the worst scenario, is there a way to modify the bios to ignore that module and end with a 5.5 Gb card???? (or 5, or 4, doesnt matter, just dont want to throw it away) Its the 12 of 12 modules, so its the last one. Searched on internet without success.
              Thanks a lot
              12-09-2021, 09:39 PM
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • DynaxSC
              Each GPU reballing produces different MATS results, looking for root cause ?
              by DynaxSC
              I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
              1. When I received the card Mats showed one memory with errors.
              2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
              3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
              4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
              5. Made...
              12-11-2024, 07:44 PM
