DPS5020 dual power supply build
  • redwire
    • Dec 2010
    • 3912
    Re: DPS5020 dual power supply build
    You short each winding and measure capacitance from pri-sec, pri-core, sec-core.
    It's good to know how much the leakage currents might be. Some 600VA big toroids are 100's nF pri-sec.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #62
      Does "core" in this case refer to the metal chassis of the transformer where earth would go ?
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        #63
        Got the caps today. As you can see, they claim to be Nippon Chemi Cons
        Wattevah...
          • Jul 2011
          • 6059
          What makes you think that they are not real
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            #65
            Ok, maybe I was a bit harsh on Ali with that statement. Funny thing is that I once saw a video of Dave from EEV Blog where the took apart a cheap subwoofer and projector and he found some Elna and NCC caps inside and he was having a very hard time believing they were real. The people in the comments however disagreed with him and pointed out that it's unlikely they'd counterfeit the logos on the caps as well, so it could be the same in my case
            Wattevah...
              • 31163
              i'v not seen fakes with snap-in style base.
              i suppose a company could re-sleeve another brand, but it's unlikely - they arent cheap to begin with.
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                #67
                Correct - they were not exactly cheap, so here's hoping they don't bulge after a few hours
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #68
                  Back on this project, I was thinking of adding an NTC thermistor in series with the secondary of the transformer to limit inrush on those large caps after the bridge rectifier.
                  Wattevah...
                    • 31163
                    i wouldnt bother, the Q of the transformer will limit the inrush.
                    • redwire
                      • Dec 2010
                      • 3912
                      If the primary fuse is slow-blow and it can handle it, then I would keep it simple.
                      Above around 20,000uF is when I add a soft-start to a mains transformer, or just listen to the mains wiring rattle in the walls when I turn on power.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        #71
                        Speaking of fuses and stuff "blowing". I once had a freak mishap with my existing supply made from the same UPS transformer: it tripped the main breaker when I plugged it into the wall outlet. To this day I have no idea why it happened, but it hasn't happened since...I thought inrush current caused it, but that means it should've tripped again after that as well, which it hasn't done so far, so I have no idea what that was all about I saw a little spark flying out of the wall socket as well, so maybe it was a faulty outlet, though I remember wiring that outlet myself and plugging in lots of stuff in it before without a care....strange :|
                        Wattevah...
                        • redwire
                          • Dec 2010
                          • 3912
                          Big power transformers, they can be magnetized when you switch off power.
                          The flux alternates between N and S at 50/60Hz but say you unplug it when the core is at peak N. Then you plug it in for peak S, and you get a bigger than usual inrush current. The core has to flip magnetic polarity.
                          It just depends on the mains sine wave phase when you unplugged it and when you plugged it in again.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #73
                            Ok, but how long can it remain magnetized like that ? It had been more than a couple of days when it happened
                            Wattevah...
                            • redwire
                              • Dec 2010
                              • 3912
                              The core is steel, it can stay magnetized for a very long time.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #75
                                I see. Any way to "de"magnetize it ? Like shorting out the primary ?
                                Wattevah...
                                • redwire
                                  • Dec 2010
                                  • 3912
                                  It happens in all transformers, residual magnetism in the core. The only way to demagnetize is apply a lower voltage sine wave and then slowly dial voltage down. It's kind of like demagnetizing a screwdriver or cassette tape.
                                  The formal name is "magnetizing inrush current" and it's why some transformers literally jump up in the air or blow primary fuses for no reason when they are energized, on the odd occasion. The core has a high (up to 90%) flux, just sitting there and then applying power the sine wave adds flux on top of that. I think some cores can saturate when that happens.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    #77
                                    Interesting. Transformers go a bit over my head as far as electronics theory goes - a LOT of math in there, but at least I got the basics One of the more complex electronic components, with a lot of stuff going on in that little heavy metal box - flux, current, capacitance, resistance, turn ratio....etc. it's got it all
                                    Wattevah...
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      #78
                                      Ok folks, I'm back on this project. I started working on the case today (or rather my old man did according to my instructions and tastes, as I'm a bit of a noob when it comes to machining metal stuff at this great precision ) and in the meantime I was gathering whatever parts might still be required. I've hit a bit of a snag however when it comes to those USB ports: remember the two modules can be connected via USB to a piece of software that controls them from a PC....pretty useless in the grand scheme of things, but if it has the option, I'd surely like it to work too. Trouble is, if I connect the two modules to USB, the grounds would become common through the PC or hub or whatever. It's not a problem if I'm powering something like a TV main board which requires two supplies (5 and 12v for instance), since the GND is common by default there, but if I want to go split-supply (+/- 12v for instance), that's not going to work, is it ? I found this isolator thing on Ali which according to the datasheet for the ADuM3160 chip it uses has separate GNDs and might do the job. Pretty pricey for my taste and I'd need two of them ! Am I at least looking at the right thing ?
                                      Wattevah...
                                        • 31163
                                        no, the usb to serial boards are optically isolated.
                                        as long as they are not touching the metal case the pc wont be referenced to the psu's
                                        • Dannyx
                                          CertifiedAxhole
                                          • Aug 2016
                                          • 3912
                                          #80
                                          But doesn't the outer shell of the USB connectors do just that ? Plus, isn't the black GND wire inside the USB lead common across all devices ?
                                          Wattevah...
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • kitedude
                                            DPS5020 "power supply"
                                            by kitedude
                                            Hello. I have the dps5020 and I've blown the mosfets which I've replaced but the D5 diode is unrecognizable.Maybe someone has the schematic or the same device? Anyone knows what it is and where does the cathode go? (left or right) I'm a noob so I know nothing about anything. Complicated answers will not be understood.
                                            Damage was due to reverse polarity for a second but it worked for months with bulged mosfets, then the final blow was more input voltage than 50v.​
                                            11-26-2024, 04:55 AM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
