Analog Scope vs Digital Scope
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Just thought I would raise his topic to see where it goes
    I have three scopes now
    A Rigol 1052
    A Techtronix 485 B
    A LG OS-5020 with built in function generator
    Generally my favourite tool at hand is one of my analog scopes, and so far my first choice is the 485B but I have not had time really to try the OS-5020 yet.
    This is because I like the instant way the analog scopes display a waveform, I always found my Rigol to be much slower at displaying anything
    That's not to say the Rigol, with it's storage facility, does not have it's uses the analog scopes can not fulfill.......
    So I was wondering - is that just me being old skool - or are analog scopes, in general, better than these new fangled digital ones?
    dicky
    Follow me on YouTube
    Learn Electronics Repair
  • srhofmann
    • Aug 2016
    • 135
    • usa
    Re: Analog Scope vs Digital Scope
    I have a 475A that just keeps going and going. With a quick glance you can tell how it's setup. No punching buttons to drill down to a menu to set something. Twist or push and it's setup and good to go. Not to say that there aren't advantages to digital scopes but I will have an analog scope until the day I die.....
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Heck....One reply and it seems I am not alone in being old skool regards my analog scope(s)
      But would be nice to see the arguments for the digital ones
      dicky
      • redwire
        • Dec 2010
        • 3912
        I've used the latest Agilent/Keysight digital scopes and many, many times the buggy firmware gives you an outright lie about the signal you are seeing. I would actually use two scopes (hail Tek!) probing the same point to confirm, "yup the Agilent is full of it".
        Digital scopes are better to measure known, predictable waveforms, like a boring sine/square wave at low frequency or very high freq.
        For looking at noise and mV signals analog scopes are superior to digital scopes.
        • retiredcaps
          • Apr 2010
          • 9271
          I don't own a scope, but I can understand the need for both analog and digital.
          I own digital multimeters, but I can see the usefulness of an analog one for certain types of readings where the digital one would be too slow.
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            If I had to buy a scope, I would probably go digital primarily for space and easier to read lcd screen.
            Unless, I can get an used digital one for under $50 CDN, I won't be owning a scope anytime soon. Nor do I need it right now.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              I have both a digital and analog ... meters and scopes...
              It all depends on what you need to do.
              Right now I've only need to use my analog scope but I try to use my digital one when I can for the heck of it, just because it can do automatic measurements despite having no need for them. My passive analog meters get used when I need to monitor a voltage and not have a power source nearby, though my DSO probably has faster reaction time and is equally usable...
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Yeah I have an analog multimeter as well as a couple of digital ones. My Fluke autoranging DMM is my weapon of choice but it is no good when voltages are varying at slow rates, which is where the analog one really comes into it's own.
                I also find the analog one useful for another reason - when you put it on the low ohms range it makes a bleeping noise to indicate continuity, and if you use it to test the resistance of a speaker coil the noise actually comes out of the speaker under test! Real handy that.
                The Fluke also has a bleeper on low ohms range and diode test too - but that won't drive the sound out of a speaker.
                Rich
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  Yes that's true, my passive analog meter in Rx1 mode sends out a ridiculous 250mA or so to measure resistance and can blow sensitive semiconductors. My DMMs in 200.0 ohm mode also dumps some current but not nearly as much as that analog. I don't remember exactly how much, nor my autorange FETVM dumps out when measuring low resistance.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    Correction:
                    Eico 555 VOM Rx1: 115 mA (measured with RS 26-216 FETVM)
                    RS 22-216 FETVM Rx1: 5mA (measured with Eico 555 VOM)
                    BK 2833 DMM 200.00 ohm: 1mA (measured with RS 26-216 FETVM)
                    The Eico lights up a Joule thief circuit easily. Not sure about the other two, something else to try...
                    • srhofmann
                      • Aug 2016
                      • 135
                      • usa
                      My two cents on analog vs digital meters.
                      My goto meter is a fluke 85. It's taken a beating over the years. Love the fact it has separate switch positions for AC and DC volts. Downside is the fuses in it are expensive.
                      Got a couple of analog Simpson meters. They're nice because they aren't too sensitive. I've been burned before when an autoranging AC/DC digital voltmeter was reading noise instead of what I was really looking for and I didn't see it was showing AC volts instead of DC.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        I just discovered one of my receivers have a signal problem...
                        Since my DSO is hooked up to GPIB to one of my PCs, I'm going to go use my analog scope so I don't have to disconnect it...
                        • japlytic
                          • Oct 2005
                          • 2086
                          Digital scopes give you many more features an analog scope can't do (now, digital scopes are just as good as the analog ones), such as retaining the last captured waveform (especially single shot), measuring frequency on part of a waveform, or even saving a waveform for regeneration with an AWG (arbitrary function generator).
                          I've bought a LeCroy, and I am in no way dissatisfied with its performance and features.
                          • oshimapt
                            marantz sr6012 no sound
                            by oshimapt
                            hello guys,
                            first of all i'm not a qualified repair guy, i am a diy guy and as years pass by i have some experience on repairing eletronics, and i'm hoping someone can share their experience.
                            i have a marantz sr6012, some times it turns on and works normal, but after a while the sound cuts off or it starts getting distorted and then cuts off.
                            when this happens there is no audio no matter the source used, and the OSD shows unknow audio signal from the source.
                            i was reading very carefuly the service manual and it is all pointing for...
                            10-17-2024, 09:49 AM
                          • repair-it
                            Need advice testing a samsung power supply board with scope
                            by repair-it
                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                            07-12-2025, 11:00 AM
                          • goodpsusearch
                            Sony STR-DE445 did I get a faulty IC?
                            by goodpsusearch
                            Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
                            First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
                            So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
                            I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
                            Also fixed A LOT of cold solder joints and also done some modifications,...
                            04-15-2023, 04:16 PM
                          • BigOof
                            Marantz SR5007 popping on volume change and mute in Direct Mode
                            by BigOof
                            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                            12-12-2024, 06:15 AM
                          • dreamlayers
                            Weird clipping on Logitech Z-10 speakers
                            by dreamlayers
                            I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                            05-22-2025, 11:41 AM
