Using my CH341A.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Using my CH341A.
    I bought my CH341APro and it arrived in the mail today. It's very similar to this one: https://tosiek.pl/wp-content/uploads...programmer.jpg
    It's the same colour and has the same components, but the three caps in the upper left of the board in the picture are all aligned, but on mine, the third one is a bit further down physically on the board. I probably have some clone or something.
    Anyway, I want to try dumping the firmware on this 25Q16BSIG. The pins I have on the 25Q16BSIG are:
    CS#, SO, WP#, VSS, VCC, HOLD#, SCLK, and SI.
    I'm not going to be using the ZIF socket but the headers to hook to my 25Q16BSIG. On the underside of the CH341A, I see the pins are header pins are labeled like this:
    Code:
    5V		5V
    3.3V		GND
    GND		RXD
    MIOS	TXD
    MOSI	3
    CS		2
    CLK		1
    I see where it says 1-2 are something, but it's in Chinese. 2-3 are for TTL (and then there's chinese). This SPI flash chip has a full voltage range of 2.7VDC ~ 3.6VDC, so I'm going to leave it on 1-2. I'm assuming TTL is for 5V TTL logic devices.
    RXD and TXD, to me, are transmit and receive for serial devices. I'm wondering if maybe the left side, that has the 5V pin, the 3.3V pin, the GND, MIOS, MOSI, CS, and CLK pins are for this type of chip and maybe the other side with the 5V, GND, RXD, and TXD are for some other type of chip.
    I'm thinking I should hook the 3.3V pin to the VCC pin on the SPI flash chip, the GND to VSS, the CS to the CS# on the chip, the CLK to the SCLK on the chip....but then what? MIOS to the SO pin on the chip and MOSI to the SI pin on the chip? Or vice-versa? Or do I hook the TXD to the SO (data output) and the RXD to the SI (data input)?
    Everyone on-line seems to just put the chip in the ZIF or use the soldering PCB that came with it. Any suggestions?
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Using my CH341A.
    I figured it out using the continuity meter.
    Code:
    chip    adapter
    CS#  ->  CS
    SO  ->  MIOS
    WP#  ->  3.3V
    VSS  ->  GND
    VCC  ->  3.3V
    HOLD# ->  3.3V
    SCLK ->  CLK
    SI  ->  MOSI
    Because I only have one 3.3V jumper, I think what I'm going to do is just use the head strips that came with it and put them into the ZIF socket and then use my jumper wires and connect them to those header pins in the ZIF socket, then use my 8-pin adapter to click onto the SPI flash chip and try to read it.
    • Spork Schivago
      • Mar 2012
      • 4734
      I wonder if I can dump something like this:
      http://pdf1.alldatasheet.com/datashe...-10SE-2.7.html
      With this device. I have a TV I can't order the same replacement board for. I have one, came from the same make and model TV, but is different a little, believe it or not! I'm wondering if I switch the EEPROMs around if the newer replacement board would work....while I'm at it though, I'd like to dump the EEPROMs. It'd be nice if I could do that using this device.
      • Spork Schivago
        • Mar 2012
        • 4734
        What worries me is those address lines. My CH341A has markings for two different types of chips, 25 SPI BIOS and 24 I2C EEPROM
        These Atmel chips have the numbers 24 in them, so I'm thinking it can maybe read and write to them, but there's no header pins for addresses. I believe the 24 I2C EEPROMs use the TXD and RXD header pins, not the MOSI and MIOS. I think I'm going to try it though. Worse case, I ruin one of the chips. Worse case, I just unsolder the EEPROMs from the bad board and put them on the good board. I'll try dumping the EEPROM from the good board, the one that doesn't seem to work with this TV, and see what happens.
        • Spork Schivago
          • Mar 2012
          • 4734
          Blah! I can't dump this EEPROM. The software supports the Atmel chip I'm trying to dump, the 24C04A. I've tried multiple versions of the software. Every time, I have to add an exception to my Anti-virus program because it flags it as a virus, even Stj's upload. I don't think it's a virus, just a false positive. The newer version of the software (version 1.29) says there's no driver, but device manager shows the device under Ports (COM and LPT) as a USB-SERIAL CH341A (COM3).
          It's a SMAKN® USB Programmer CH341A. This sucks. I don't know if the chip is bad, or if it's a driver issue or a software issue or what. I figured if it had the CH341 in it, any of the softwares would work, but maybe I need something specifically for this device. And of course, the people who made it don't have drivers or software. They say to use Google.
          Any suggestions? I wish Stj was here!
          • diif
            • Feb 2014
            • 6978
            • England
            Did you get the little board with the header pins ?
            Start with something we know can be read the 25Q16BSIG. Solder it to the little board add the header pins and plug it into the ZIF.
            It needs putting in the correct part of the ZIF as indicated by the screenprint.
            • Spork Schivago
              • Mar 2012
              • 4734
              This is stupid. I found a video with download links for the software and drivers.
              https://www.youtube.com/watch?v=5NYe21nFSDI
              I install the drivers, still nothing. I decide to watch the video, just for shits and giggles. About half way through, the guy says the jump has to be on pins 1-2, otherwise it won't work. He's right. Even though the board says jumper 1-2 is for 3.3V and my chip I'm currently trying to read requires 5V, for some reason, when I have it on 2-3, I get device not detected. But when I switched it to 1-2 (3.3V), now I can read, write, erase, blank, all of that!
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                This might help you.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  Keeney123,
                  I got it working. The problem wasn't with the drivers or the CH341A chip, but the actual PCB. The jumper has to be set on pins 1-2 (for 3.3V). The guy in the video explains it nicely. Makes me wonder why and if there's a problem with the PCB.
                  I bought the device from Amazon and left a review and comment, telling people about the issue, giving them a link to the software and drivers (32-bit and 64-bit). It seems a lot of people who bought this device where asking where to get the software and drivers from and no one seemed to know (or if they did, they didn't respond!)
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Originally posted by Spork Schivago
                    Keeney123,
                    Glad you got it working!
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Yeah, me too! I've been talking to the developer of the CH341 Programmer for Windows. I purchased a registered copy. He only wanted 10$. I gave him 15$. He says for 10$, it'll include future updates, which is nice. I felt it was worth it. Anyway, I asked if he ever planned on making a Linux version, he said right now there's no Linux drivers.
                      I found a Linux module in the kernel but it's only for serial support. These devices also have an IEEE 1284 parallel interface, an SPI interface, and an I2C interface. It was created by some smart people studying the Windows driver. I reached out to the company who makes the Windows drivers, asking if they'd ever consider releasing the source code for the drivers so I can port them or if they'd be interested in releasing a Linux version, but I don't have my hopes up.
                      I also reached out to the guy who developed the current CH341 kernel module, asking if he ever planned on implementing the other features. Hopefully someone will provide some good news.
                      Have you ever thought about purchasing one of these? They're kinda neat.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        No, I will leave that to you genus Programmers. I just like to dabble and help where I can. When it gets warm enough I am going Undercoat my car, go to a stream and paint what I see. If my sister can not find someone to chop up this log that's 3.5 feet in diameter and 10 feet long then I will have to do it for her. Then there is the 3.5 foot stump to deal with.
                        • newguy90
                          • Sep 2019
                          • 12
                          • Romania
                          Hello!
                          I bought myself a CH341 Mini programmer (black mobo) and a SOIC 8 clip to use it for hot programming an 93c56 EEPROM , and I'm stuck because I don't know how to connect the 93cxx EEPROM to the programmer. At first, I used an old video card to test the CH431A how it's working so I connected the SOIC Clip's interface to the slot for 25XX with the no 1 pin to the left upper corner of the CH341a's ZIF lock, I attached the miniclip to the 8 pins of the videocard's EEPROM (with the red wire of the clip to the EEPROM pin no 1 - marked on the videocard with "1"), and then I connected the mini programmer to the USB of my desktop pc. The software v.1.29 shows "device connected", but nothing happens when I press the button to identify the chip. Further more, the ch341a heats up so I had to disconnect it from the usb port. I don't know what am I doing wrong.... Can someone help me, please?
                            • 31303
                            firstly, 24 series and 93 series chips have no id for the programmer to read. that only works on 25 series.
                            second, you cant program or read a chip on board unless you can isolate it's power pin or the usb programmer will try to power the whole device!
                            • newguy90
                              • Sep 2019
                              • 12
                              • Romania
                              Thank you for the quick response, Stj!
                              That means that I will have to choose from the drop down list the 93c56 EEPROM that I want to read/programm? what if I don't find it listed? Can I select another with similar memory size?
                              I read on internet that it can be done on board, all I need is to short the crystal oscillator without any other modifications (the 93c56 is on a car ECM). If it can be done, why did they make a SOIC Clip? On the internet its advertised that with this clip one can programm the EEPROM without any desoldering.
                              • R_J
                                • 9633
                                Shorting the crystal will help by stoping the micro from trying to acces the eeprom/spi ic at the same time, but you still have to power everything connected to vcc of the eeprom. Some pc's usb can't supply enough current for this and you may need to use a seperate +5v supply.
                                • newguy90
                                  • Sep 2019
                                  • 12
                                  • Romania
                                  Ok, thank you for your inputs.
                                  Supposedly that I have a new 93c56B EEPROM, how do I have to connect it to the CH341a in order to program it? From the 93c56 datasheet I can see no match between the pin configuration of 93c56 EEPROM and the ZIF lock of the CH341a PCB.
                                    • 31303
                                    does the software list it?
                                    • R_J
                                      • 9633
                                      I found this information on using a CH341a and 93LC86 microwire https://freesoft.dev/program/171504972
                                      93C56b is microwire
                                      • newguy90
                                        • Sep 2019
                                        • 12
                                        • Romania
                                        The CH341a software that I've got, doesn't list 93Cxx EEPROM series... So I'm still wondering how can I connect the 93c56 EEPROM chip so I can program it.
                                        Blah! I can't dump this EEPROM. The I've tried multiple versions of the software. Every time, I have to add an exception to my Anti-virus program because it flags it as a virus, even Stj's upload. I don't think it's a virus, just a false positive. (COM3).
                                        When I'm testing the CH341a software (v1.29, v1.3 etc) that I found on the internet, using the Virus Total website, it shows me that it is infected with malware (one of them it is flagged by 17 antivirus engines!). Are they just false positives, or not? Where can I find a clean and newer version of this software?
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                        • pengamat_hebat
                                          Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                                          by pengamat_hebat
                                          I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                                          Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                                          However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                                          I also tried applying 3.3V to pin 3, but it still didn't work.
                                          I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                                          03-25-2025, 04:13 AM
                                          How to add chip support to NeoProgrammer software for the CH341A Programmer
                                          by SMDFlea
                                          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                          and once you do find them there`s a few crucial steps missing.
                                          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                          After adding the chip save the xml file and copy it to the root directory of the...
                                          05-26-2024, 07:15 AM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
