Need software for Intelligent universal programmer lk48
    Re: Need software for Intelligent universal programmer lk48
    the link in post #68 still works.
      I have download the V12.40 and the offset 03CDD0 is not 55 its c0. I use the Hex editor Neo.
        did you install it first?
        you patch the actual program exe file, not the installer.
        btw, you can also use the latest 12.60 i think
          Yes, I patch the installed exe file.
          Is the Dataman and Labtool program the same?
            are you using the XP version and not the UXP one?
            the patch is only for the 48XP software.
              Downloaded from the link in the #68 post.
                yes, but when you install it it creates 2 seperate exe files.
                i'll check it again later - i'll have to setup a damned windows laptop first though.
                not something i normally have here.
                  It's only one exe file in the labtool-48UXP foler, WLT48UXP.exe for the V12.40.
                    When you install you get 2 main folders: xyz-48UXP and xyz-48XP;
                    The 1st is for the USB programmer version, and the 2nd for the LPT programmer version;
                    The patch is only valid for the one on 2nd (...48xp.exe) not for the one on 1st (...48uxp.exe)!
                      it's only one folder C:\Program Files\Advantech Equipment Corp\Labtool-48UXP
                      Installed on a W10.
                        it's only one folder C:\...\...\xyz-48UXP
                        Installed on a W10.
                        Install the version on the previous links, XP/Vista/7, only!
                        Use compatibility mode in w10 to install.
                        Please do us all an obvious favor:
                        Edit and remove all obvious strings: Advant3ch 3quipment, labt00l, ...
                        We really do not need the devil's search engine to find us...
                          lol
                          posting a couple of hexadecimal numbers is not illegal - fuck them.
                          and iMac - use the latest version, not the old 12.40 one.
                          at the time i'm posting this, it's 12.60
                            Originally posted by stj View Post
                            lol
                            hi,
                            i have labtool 48 xp and i try to modify software.
                            but my problem is when install it. i have only one folder in my pc and offset on software have another value
                            help me please
                              so your using LT48UXP_1300_WIN7.exe ??
                                i try before 10.50 (for my use is good) and after other version, but whe install it, i have one folder with one exe (uxp)
                                Help me please
                                thanks
                                  on 13.00 try changing address 20591f = 55 >>> c3
                                  i cant test it, i dont have the programmer and using windows makes me want to throw the laptop at the wall!
                                    i dont have doble exe
                                      look this photo
                                        yes, in there is the exe file
                                          but is presente exe only uxp, not exe for parallel port. i have labtool with only parallel port because usb is dead. on old pc with XP work fine, but old pc is dead
