Need software for Intelligent universal programmer lk48
    • 31196
    Re: Need software for Intelligent universal programmer lk48
    Dataman 48 is the same programmer
    https://www.dataman.com/dataman-4848lv-resources
    • hbest
      • Mar 2020
      • 6
      • france
      #42
      i used all the version dataman but still the some problem
        • 31196
        is your port set in the bios to EPP ?
        • hbest
          • Mar 2020
          • 6
          • france
          #44
          no it 's ECP , one chose in bios ECP
            • 31196
            i think EPP was mentioned on the website,
            also try running it as administrator - i'v seen some firewall/security software block the ports on windows.
            • megaraider
              • Jul 2015
              • 307
              • Portugal
              #46
              Originally posted by megaraider
              In BIOS settings try changing the LPT port mode to EPP.
              Also make sure LPT1 is set to port 0x378.
              Make sure you're using a full EPP wired cable.
              Ensure you're using the LPT port software version 'WLT48XP' [not the USB version (WLT48UXP)]!
              Change port settings to above in BIOS settings & try it out
              • hbest
                • Mar 2020
                • 6
                • france
                #47
                All my port is ECP , i used 4 pc it all ECP .
                  • 31196
                  so change the setting then.
                  • bootboy
                    • Mar 2019
                    • Unknown
                    #49
                    first question, which os are you running on your PC?
                    Hi, i've three labtool48 programmer, and there's no official/legit way to make them work under windows xp+ OS
                    the latest software taken from dataman, aec or other pseudo manufacturer is the v4.67
                    running the software under windows xp didn't recognise the programmer at all, same gear but different os like windows 2000 works great.
                    so i didn't remember now because i have a dedicated setup for eproms programming but you can be succesful running the programmer within windows xp too even in a virtual machine.
                    first try to set the compatibility mode of the programmer .exe software to windows 2000 or windows 98, and give it a shot.
                    if this didn't work you should try the programmer on a real win 9x/2000 environment and be sure that it's working.
                    by the way hacking the software or patching the firmware inside the programmer should do the trick.
                    before proceeding further let us know.
                      • 31196
                      if it's parallel-port then this can fix it.
                      • zjta0k
                        • Jun 2016
                        • 10
                        • Swiss
                        #51
                        @stj: Could you send me the fixed software for the 48XP that is mentioned in the first page of thread? TIA.
                          • 31196
                          it's not a fixed version, it's a patch.
                          download version 10.50 - it's the newest i cracked.
                          install it.
                          then open the exe in a hex editor and change the byte at location 0x01e433 from 55 to c3.
                          then save and your good.
                          • zjta0k
                            • Jun 2016
                            • 10
                            • Swiss
                            #53
                            Thanks!
                            • zjta0k
                              • Jun 2016
                              • 10
                              • Swiss
                              #54
                              Does someone know if a PCMCIA (Not PCI-Express) parallel adapter works with the labtool software?
                              And what about the USB2LPT (https://www-user.tu-chemnitz.de/~heh...index.en.htm)? Is it usable? Seems to use the same Cypress device (CY7C68013A) that the UXP uses.
                                • 31196
                                no idea - probably not because the software has the damned driver built-in.
                                • zjta0k
                                  • Jun 2016
                                  • 10
                                  • Swiss
                                  #56
                                  No idea about the PCMCIA or the Cypress?
                                  Does someone have an UXP and can map the CYpress chip connections (on the i/o side)?
                                    • 31196
                                    you also need to know if the cypress has a custom VID/PID number in it's eeprom
                                    • zjta0k
                                      • Jun 2016
                                      • 10
                                      • Swiss
                                      #58
                                      I thought the VID/PID were known
                                      Originally posted by ducky29
                                      USB\Vid_0574&Pid_ea80&Rev_0001
                                      But anyway it wouldn't work, as the software would want an UXP to connect to.
                                        • 31196
                                        yes, the software is 2 different versions - usb, and parallel.
                                        i only hacked the parallel - the programmer didnt have usb.
                                        i have been told that the usb version is not any faster btw.
                                        • megaraider
                                          • Jul 2015
                                          • 307
                                          • Portugal
                                          #60
                                          IMO somewhere along the way you mixed 2 different scenarios thus falling in a dead end trap.
                                          1. The programmer parallel version connected thru an USB2LPT adapter to the computer USB port will still require the parallel software version (NOT the UXP version)!
                                          That's easy to understand as the USB2LPT adapter will create a virtual LPT port!
                                          2. If you bought the seller parallel to USB adapter kit, for an outrageous price if I do recall it correctly, then, and only then it would expect, and only work, with the UXP software version.
                                          Although I stand for my opinion, I'm not claiming it would work or not,
                                          but only sharing a light on the right approach to be taken.
