Oscilloscope Poll! How many do you own?
    • 30919
    Re: Oscilloscope Poll! How many do you own?
    a lot of the time you get eeprom fail messages on the old atari arcade stuff, it's not the eeprom,
    it's just the high voltage supply failed.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8663
      Oh nice. That's good to know, also the fact that after writing highscores into EAPROM I don't know how often people get new high scores.
      Tektronix did a decent job of designing the power supply I think, but writes into the EAROM too many times in the same spot - so it truly is worn out.
      I think the policy is that it writes the control positions into EAROM after 8 seconds of inactivity. If someone constantly futzes with the controls (I suppose this is hard to do...wow...) or there's a noisy control, then perhaps this is how these EAROMs get destroyed.
      No wear leveling to see here!
      • diif
        • Feb 2014
        • 6978
        • England
        #63
        It was slightly more than a fiver, but it's on it's way.
          • 30919
          what - you got the d755?
          • diif
            • Feb 2014
            • 6978
            • England
            #65
            Yeah, arriving tomorrow. What reconditioning have you done to yours, new caps ?
              • 30919
              mine was bad, i recapped it, but also replaced the BNC and 2mm sockets and replaced the mains inlet with a regular type.
              infact i need to check the timebase module soon,
              now i have the component tester that will be quick.
              the modules pull out and all transistors are in sockets!
              it's the best scope i have ever worked on btw - everything is easy to get to.
              the top and base unlatch and the two modules next to the crt just slide out leaving the HV and regular psu's in the base.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8663
                Ahh... I think I got my 2440 DSO to play Oscillofun...sort of - it's very weak and fuzzy but barely can make the picture out. It's struggling to display it. Beams of Light is completely broken - cannot make heads or tails. I'm using the generational problem (YT audio, not using the FLAC) so it's hurting the scope a bit. But still can see something.
                Right now the recorded movie is 462MB and I don't feel like uploading it somewhere as my uplink is miserable. May have to do some more generational loss and compress it first...
                  • 30919
                  that wont work - ever. YT re-encodes everything.
                  follow the link to get the original mp3
                  https://www.scene.org/file.php?file=...s_of_light.zip
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #69
                    Glad I'm not the only one who likes to see what dumping audio into a scope will look like... Try Boards of Canada - Dayvan cowboy.
                    Follow the white rabbit.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8663
                      OH FSCK THEY'RE CHEATING
                      Originally posted by iRATA
                      You will need a sound card and an oscilloscope to run this prod. You can use the included emulator if you do not have either. This demo uses multi-channel audio data in the WAVE signed 16 bit PCM file format. The front left and right channels control the horizontal and vertical axis of an oscilloscope set in X-Y mode to produce vector graphic images. The rear left and right channels provide the music.
                      I thought it was 2 channels only like Oscillofun?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8663
                        I just downloaded the wav file and playing it. Yeah, video and audio is on separate channels. This is cheating. Oscillofun only requires 2 channels for both audio and video.
                          • 30919
                          how is it cheating?
                          it's a demo - the music should be clear and not full of out-of-band noise,
                          and the imagery should be clean and not superimposed on a strange blob in the center of the screen.
                            • 30919
                            hey, want to build yourself the arcade game "BATTLEZONE" to play on a scope?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8663
                              It's more challenging to superimpose the music on top of the actual video.
                              There's a bunch of videos out there that have oscilloscope art, but Oscillofun is the only one that actually has music embedded in the art so you can play and view at the same time on 2 channels. Even MP3 compression, though it degrades everything, does not completely destroy it.
                              I couldn't find the FLAC/wav for oscillofun, would be interesting what that looks like without the compression artifacts.
                              Here's my 2440 playing Oscillofun: https://www.youtube.com/watch?v=yaGDA-dTkWo - it's playing with compression artifacts. Added with the scope slowness, it's pretty crappy despite being a 300MHz scope...
                              • Compgeke
                                • Feb 2014
                                • 524
                                Here's the FLAC version of Oscillofun: http://www.pouet.net/prod.php?which=58317
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8663
                                  Dang now I have to make another video :p (and dub in the real track...)
                                  And set it up again...
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8663
                                    I just realized - the Eico 460 actually has rudimentary triggering "sync" ... Probably to follow suit with Tek.
                                    It also has Z axis - so raster images are possible with XYZ mode.
                                    I don't know why but suddenly I have an urge to see Oscillofun on the Eico 460...
                                    • vanel
                                      tektronix 5103n(D11) Oscilloscope creap
                                      by vanel
                                      I tried to figure out which section this belonged in, but imaging is the one that seemed closest. I have a tektronix 5103n(D11) and the horizontal line is always slowly creaping down. Even if I have it probing a voltage. I tried probing a 9V battery and it would show 9V at first then very slowly keep moving down. Is there an adjustment I can make or is the scope in need of reapir? Thank you.
                                      10-07-2023, 07:34 AM
                                    • FuzzyOwl
                                      Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
                                      by FuzzyOwl
                                      Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
                                      Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
                                      Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
                                      I've followed the trouble shooting guide, audio check...
                                      12-05-2024, 11:54 AM
                                    • Tarot Superstars
                                      How not to Damage an Oscilloscope
                                      by Tarot Superstars
                                      Hello.
                                      I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                                      I want to learn how not to damage it, and I found instructions on the internet obscure.
                                      They talk about ground, earth, floating ground, this, that....
                                      But they don't actually say anything anything useful so far.
                                      I want to know:
                                      Don't connect exactly this to exactly there or it blows up.
                                      For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                                      I want to know what not to connect...
                                      08-29-2023, 02:27 PM
                                    • eccerr0r
                                      lowest current galvanometer/analog meter (passively powered!)
                                      by eccerr0r
                                      Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                      On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                      04-16-2025, 12:41 AM
                                    • Evets
                                      Dynamco analogue oscilloscope
                                      by Evets
                                      I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                                      08-30-2024, 06:54 AM
