Any opinions on either this ESR meter kit website?
  • xelectech
    retired tech
    • Nov 2014
    • 238
    I'm finally almost ready to get an esr meter, decided on a kit so I can get some extra familiarity with it, here's what I'm considering:
    http://electronics-diy.com/store.php...&sub=esr_meter
    Any comments yea or neigh, any one done business with the website?
    Thanks in advance for any help,
    Mike
    • 31285
    Re: Any opinions on either this ESR meter kit website?
    $40 for a first generation esr meter in bits vs $15 for a second gen graphic version built?
    that 1st gen unit will be almost useless with the newer software.
    if you really want to build one, look at this.
    http://www.ebay.com/itm/221952423890
    2nd gen design with graphic display and rotary encoder.
    • xelectech
      retired tech
      • Nov 2014
      • 238
      Hmm, that looks pretty tempting, except I've never bought anything over the web with a CC;
      After reading about their version, I was going to ask 'em about using a gift card or prepaid debit card, but found that I'd have to register, plus enable javascript to use that function, which is something I generally avoid doing.
      In their description they say,
      "Capacitance measurement range from 25pf to 100mF (10 万 UF)" ,
      do you happen to know whether they actually mean 'milli-' or 'micro-' farad? that chinese-looking character in parentheses kinda throws me. I'm also wondering what they mean by the phrase 'European resistance', I'd look at the detailed instructions except I'd have to register to do that as well.
      Anyway, thanks for pointing out that newer model, now I have some questions I need to ask the DIY-place.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        There are other sources for the equivalent device and I'm surprised STJ didn't point you to his thread on upgrading one of these:
        http://www.aliexpress.com/item/2015-...355885481.html
        Oh yeah, if I am not mistaken that "mF" is actually millifarads cuz I know them suckers don't stop at 100 uF.
        • xelectech
          retired tech
          • Nov 2014
          • 238
          Thanks for your reply. I've been following the ESR upgrade thread, this talk of 'software'
          kinda spooks me a little bit. I guess I'll try to see if I can use a prepaid debit card with alibaba (without enabling javascript). I don't hold much hope for that, though...it's hard being a luddite sometimes.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            You don't have to do the upgrade stuff, the tester works great as is.
            • xelectech
              retired tech
              • Nov 2014
              • 238
              Cool - I'm looking forward to finally having a way to test for esr, plus the other functions the meter is capable of doing. Also have a growing collection of replaced capacitors, some bulging, some not...
              • chth96
                by chth96
                03-09-2024, 10:03 PM
                12-31-2023, 06:04 AM
              • jorpec
                by jorpec
                Hi
                Thnaks
                01-23-2023, 10:37 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • Stephan Mathers
                EDMI ATLAS MK10 Electronic Meter Discussion
                by Stephan Mathers
                Greetings, new guy here but always interested in the crazy universe of modding
                We just finished construction of around 25 vacation houses, all inside the same private area.
                Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                05-20-2025, 09:09 AM
