ESR meter upgrades
This is a sticky topic.
    • 32068
    Re: ESR meter upgrades
    no, arduino is pre-programmed and the code is loaded by com-port.
    you need a usbasp programmer
    http://www.ebay.com/itm/321509199187
    • xelectech
      retired tech
      • Nov 2014
      • 238
      • cycling, tech-type stuff, recycling...
      #102
      Ok, thanks...how about this one with a 10 to 6 pin adapter? Just looking to save a little DIY time, if possible...
      http://www.ebay.com/itm/USBASP-10-to...-/181215336077
        • 32068
        instead of spending $5,
        why not just spend half that!
        http://www.ebay.com/itm/310635615426
        you even get a spare!
        • xelectech
          retired tech
          • Nov 2014
          • 238
          #104
          Looks good, thanks!
            • 32068
            updates.
            trendy now does opto's
            8 & 16MHz builds included.
            • upsss
              • Mar 2016
              • US
              #106
              update:
              btw, i'm willing to compile this for the T3 / T4 boards if asked.
              Hi I would like to try your latest firmware compiled for the T3/T4 tester version which I have and I added the rotary encoder.
                • 32068
                ok, try this.
                i need you to go into the menu and check the encoder works o.k. and in the right direction.
                then go into the contrast menu and find the best contrast value.
                finally, use a meter to check the battery voltage while it's on the lcd to see how close they are.
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  #108
                  updates.
                  For some reason I was thinking there was only 32Kb of room for the program, am I way off
                  base?
                    • 32068
                    no, 32k flash, and 1k eeprom.
                    why?
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      #110
                      why?
                      well, because, the size of the update files you've been putting up here started out at a bit below 32k in size, but kept getting progressively bigger, so it seems that either you've found a way to compress the files when loading them or I totally misunderstand what the update files are about.
                        • 32068
                        hex files.
                        they are just over twice the size of the binary data because they contain address and checksum info.
                        also, each zip contains 2 versions and i now included the source files i modded.
                        • xelectech
                          retired tech
                          • Nov 2014
                          • 238
                          #112
                          hex files.
                          Oh, ok, I hadn't tried unzipping one yet, I'll try that and see what I see - Thanks
                            • 32068
                            i'm not sure why 3 people downloaded the T4 code without posting answers to my questions afterwards - that code is not tuned or complete!
                            • xelectech
                              retired tech
                              • Nov 2014
                              • 238
                              #114
                              say stj, I'm wanting to change from the atmega168 that's in my d-i-y esr meter kit to an atmega328 - from what reading I've done, it sounds like it should be doable once I have some kind of programming setup, what do you think? I was thinking of getting the 328 IC from digikey...
                                • 32068
                                the 328p is a direct swap.
                                they are probably cheaper on ebay though.
                                • xelectech
                                  retired tech
                                  • Nov 2014
                                  • 238
                                  #116
                                  Well, I tried ebay, wasted 2hrs. trying to find a seller who'd ship to a po box - then, went through the 'checkout as a guest' all the way past entering my debit card # and they wanted a different debit or cc #. It's worked fine on 2 other occasions, and I know how much my balance is, so wonder wtf...
                                    • 32068
                                    what tester is it?, foto's pls.
                                    • xelectech
                                      retired tech
                                      • Nov 2014
                                      • 238
                                      #118
                                      https://www.badcaps.net/forum/attach...6&d=1454416833
                                      https://www.badcaps.net/forum/attach...7&d=1454416833
                                      A couple of pics above, here's the so-called manual below:
                                      https://www.badcaps.net/forum/attach...2&d=1454418309
                                        • 32068
                                        then you need a 16MHz crystal and a pair of 22pF caps that can fit between the crystal pins and that center hole.
                                        • xelectech
                                          retired tech
                                          • Nov 2014
                                          • 238
                                          #120
                                          Ok, thanks, I think I saw a suitable crystal at digikey for less than a dollar the other day.
                                          Now it's time to do a youtube crash course on avr programming now, I've watched a few from newbiehack.com and think Patrick Hood-Daniels does a pretty good job of explaining things.
                                          BTW, sometimes I behave like such a clown, yesterday when I was shopping on ebay I forgot to enable cookies - I still can't buy from ebay today, but that may now be because I made so many tries wo/ cookies yesterday, what do you think?
                                          • masterprince123
                                            Vintage Dick Smith ESR & Low Ohms Meter Bob Parker not working
                                            by masterprince123
                                            Hi All,
                                            I am the fortunate owner of an original K7204 ESR Meter, and it is a pleasure to have such a wonderful piece of equipment. I purchased it from eBay, although unfortunately it had not been used for many years.
                                            I am experiencing an issue with the meter. As soon as I power it on, the display shows “EA” or you can say stuck in EA. if I try to power the meter off it doesn't do anything at all.
                                            When I touch the two probe leads together to perform the zeroing, the displayed numbers jump randomly. Once I separate the probes, the display then becomes stuck...
                                            10-04-2026, 07:17 AM
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
