ESR meter upgrades
This is a sticky topic.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #421
    Re: ESR meter upgrades
    ok will test now
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #422
      Originally posted by stj
      try these: test the "fresh" build first.
      "testing-bg-kit2.zip"
      Fresh: contrast default 37, display upside down & inverted.
      Flip: Contrast default 45, display correct!
      Rotary encoder turns in the wrong direction.
      Best contrast is of course user opinion, 50 shows a little bit of the background, at 45 the background is only the backlight.
      I'd say 50 is probably good when you have some sun or bright lights anyway.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #423
        its upside down and inverted cant tell if encoder works
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #424
          per hannson thats the one ive tried on mine and works fine with the display etc just rotary encoder backwards
            • 31301
            ah shit, i thought you said the "fresh" was the correct orientation!
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #426
              fresh was hold on will reinstall and try
                • 31301
                test this one.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #428
                  per hannson is rite its the flip that works sorry stj transfered files onto a usb stick to main pc for programming so my fault.
                    • 31301
                    so i just broke it again? fuck!
                    alright, enough - is "tuning2" the right way?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #430
                      test this one.
                      "testing-tuning2.zip"
                      This one is correct.
                      Contrast is good.
                      Encoder turns in the correct direction.
                      And display is not fucked up at all from what I can tell
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #431
                        stj with your last file encoder goes the right way now i cant see any other diffrences although still dosnt show encoder in the menu but works fine.
                          • 31301
                          encoder test is disabled to save space.
                          i'm going to go start adding other stuff now.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #433
                            Contrast is good.
                            yes this one works fine for me too i was swopping files from laptop via usb to desktop pc so i got files mixed up but testing-tuning2.zip seems fine too me.
                              • 31301
                              ok test this
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #435
                                stj i just need to pop out as visitors have just came i will test any files you need later on when im back thanks again for your help.
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  #436
                                  ok test this
                                  "testing-tuning3.zip"
                                  Just scrolling line of text like on this old one
                                    • 31301
                                    fuck it, i hardly changed anything display-related!
                                    o.k. try this - if it works then your eeprom may be faulty - i'm moving the fonts into the main flash.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #438
                                      "testing-tuning4.zip" kinda worked, the fonts where not correct.
                                      And the meter rebooted all the time, never offering to do the calibration.
                                      And when metering a capacitor it showed 0.00 for ESR which was incorrect.
                                      But the display was oriented properly at least.
                                        • 31301
                                        i changed the fonts to a smaller set to fit more info on the display.
                                        the reboot i think i can fix - i tried to set the shutdown timer after vince noticed it stayed on.
                                        i'v had trouble with that bit of code before.
                                        try this.
                                        i killed the timer and removed the long cal message.
                                        (to save space)
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #440
                                          Yea "testing-tuning5.zip" works better, ESR still shows as 0.00 though which is incorrect for this cap.
                                          I put back "testing-tuning2.zip" now as I like that one better, much nicer fonts
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
