ESR meter upgrades
This is a sticky topic.
    • 32045
    Re: ESR meter upgrades
    i was unable to watch that all the way through, it was too painfull.
    that's why i hate utube.
    so the FSC error is because the chinese programmer auto-detects the correct speed and ignores the parameter - so ignore it.
    he pulled the chip and breadboarded it - why? just connect the header to the bottom of the programmer socket and the crystal is already there.
    his breadboard was unreliable anyway - the crystal should have a pair of 18-22pf caps to ground - he didnt fit any!
    and all you need to do for avrdude is copy & paste this:
    avrdude -c USBasp -P usb -p m328p -U flash:w:TransistorTester.hex \-U eeprom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
    job done
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #262
      well when all my bits come i will get you too help me copy the working chip contents onto the faulty chip that way i have two meters hopefully working then and can start upgrading one with your help i you dont mind that is.But will need help in the programming side of things if you dont mind as its all new too me so a guide mayhelp a few members as if everyones ic is blank on these kits there going to need too know how to programme it too.
        • 32045
        do you have a Linux setup?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #264
          only xp-vista_win 7 _win 10 at the minute but no linux never used it.
            • 32045
            hmm. have to get the libusb driver first then.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #266
              stj a question rather than add a header to the pcb for upgrading the files to the tester could i use one of these? as ive been offered one for free if i go and collect it and it may make the upgrades easier for me as ive never done programing before
              http://www.ebay.co.uk/itm/2622305495...%3AMEBIDX%3AIT
                • 32045
                i have never used one, so your on your own with the software, but i would take it for 3
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #268
                  i was wondering if it could take your modified files you upload ie the crystal upgrade etc. it will probably copy my good chip contents onto the blank kit one ok though i guess and make a working tester.
                    • 32045
                    well tbh the 10pin header is a lot simpler than constantly removing the display and pulling the chip.
                    it makes no difference to *how* it's programmed - it just saves stripping the unit to get at the programming signals.
                    you should fit the header and grab the 866 for other things.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #270
                      can you do a guide on programing it your way? as a lot of people may find it usefull and only have a windows pc etc ive ordered all the parts anyway just waiting for them too come.
                        • 32045
                        you install the libusb driver from here:
                        http://www.fischl.de/usbasp/
                        and the latest AVRdude from here:
                        https://www.badcaps.net/download/?id=16cabea3
                        http://download.savannah.gnu.org/rel....3-mingw32.zip
                        to program the chip, simply use
                        there is a slightly different command to read one.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #272
                          Hi thanks for the info stj another question for now have you got a diagram to where to solder the wires for the 10 pin header wires too as hopefully parts will have been delivered today.
                            • 32045
                            you know i do
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #274
                              Originally posted by stj
                              you know i do
                              Thanks for that stj whilst im waiting for the parts for may 2016 version tester i have one of the older type testers mine is the one without the crystal i see in the other picture it has a crystal added can i add one to this tester as im also thinking about changing the main ic too the larger capacity as its only 99p so worth the upgrade and i could update the firmware etc then can you offer any advice? this is only a spare tester but might as well upgrade it im not bothered about a rotary enoder etc i just want acurate test results.
                                • 32045
                                adding a crystal is no problem, dont forget a crystal needs a pair of 22pF ceramic caps between the legs and ground.
                                (looks like the fact that RS sells the crystals in 5's isnt so bad!)
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #276
                                  ive got 5 crystals so alls good the caps ive just ordered is there a guide which pins etc to connect the crystal and caps to my tester in picture one thanks again
                                    • 32045
                                    these probably help
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #278
                                      these probably help
                                      Thanks it sort of helps (im still la newbi remember with electronics ) so crystal legs to pb6 and pb7 with a 22p capacior on each leg to ground?
                                        • 32045
                                        no, dont know how you came up with that.
                                        crystal to xtal1,xtal2 (pb6, pb7)
                                        keep the wires short.
                                        personally i would use a pair of smd caps and just solder them between the pins on the actual crystal can.
                                        pd1,pd3 are the rotary encoder mod!
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #280
                                          sorry i edited my post as you was probably writing yours the last thing as i will be installing the larger ic too take the crystal and updated firmware how do i find the files i need to write to the chip i will need all the firmware files i guess not just the updates (i might programme the chip using that free programmer i need to collect this week ) so it will also save me adding a header on the board as i didnt order spares of them.
                                          • masterprince123
                                            Vintage Dick Smith ESR & Low Ohms Meter Bob Parker not working
                                            by masterprince123
                                            Hi All,
                                            I am the fortunate owner of an original K7204 ESR Meter, and it is a pleasure to have such a wonderful piece of equipment. I purchased it from eBay, although unfortunately it had not been used for many years.
                                            I am experiencing an issue with the meter. As soon as I power it on, the display shows “EA” or you can say stuck in EA. if I try to power the meter off it doesn't do anything at all.
                                            When I touch the two probe leads together to perform the zeroing, the displayed numbers jump randomly. Once I separate the probes, the display then becomes stuck...
                                            10-04-2026, 07:17 AM
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
