Transitor/ESR tester dead
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Transitor/ESR tester dead
    Originally posted by SteveNielsen
    This 78L05 reg (IC2 on my board) reads 3.2K ohms between Gnd and Out leads. It's not shorted. I've got a 2 ohm short downstream on the board.
    When you say downstream does that mean going to the 5 Vcc to the IC chip? If that is the case can you not lift resistors to determine where it is?
      • 30983
      I'll try making an aluminium shield over the board.
      i keep the covers from old tuners for that.
      • SteveNielsen
        Retired Tech
        • 2327
        Hmm, I've got a copper RF shield from an old Mac backplane. If I cut off the part with holes and flatten it out it might work too. OR get soldered to the board... I think I'll pass on trying that and going with the Al foil unless I dig up something better... Alright - I've got a nice Al pie pan.
          • 30983
          if the chip is bad then:
          http://www.ebay.co.uk/itm/141666259867
          and:
          http://www.ebay.co.uk/itm/261574745774
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Stj I do not think the schematic matches up with the board as the large IC is 32 pins and your schematic is 28 pins. The pin out on the 32 pin makes pin 4 the VCC.
              • 30983
              there are many schematics because it's an open evolving design and the dil chips and smd chips have different pincount.
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                this has some good info too
                http://www.cwtd.org/May7.html
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Without the chip there is 1053 ohms from Gnd to Out pads where IC2 reg was, so the 2 ohm short is in the chip.
                  Al foil in 4 layers for a heat shield worked perfectly. The chip came off sliding sideways a bit so I cleaned up the solder pads for it with wick and iron and no solder bridges or damaged pads. This is a first for me; the first smd microchip of this type I have ever tried to remove! Yay!
                    • 30983
                    good,
                    so if you jump the regulator you should see 5v - just to be sure.
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      With or without display attached?
                        • 30983
                        either - just to check the regulator wasnt damaged.
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          Ok, w/o display regulator has 4.96v on Out. 9.06v on In.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            is the software easy to get? if you go for the ebay chip/programmer.
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              My tester doesn't have the USB port and circuitry.
                                • 30983
                                the programming header can be fitted - it's the 2x5 set of holes.
                                software is easy, you download the source,
                                set the options for the type of display etc,
                                then make the hex with winAVR compiler.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  no mine dosnt either ive just found this though
                                  http://www.mikrocontroller.net/svnbr...ster/Software/
                                  http://www.mikrocontroller.net/topic/248078
                                    • 30983
                                    interesting - gonna take a while to look through that.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      just added another link ive found not sure if its for these testers though
                                        • 30983
                                        oh yes - cutting edge version!
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          All right victory!
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • maleksa
                                            Korg Kross2 Service Manual and LCD pinout
                                            by maleksa
                                            The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                            However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                            Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                            From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                            10-11-2024, 05:54 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
