Transitor/ESR tester dead
Re: Transitor/ESR tester dead
Hmm, I've got a copper RF shield from an old Mac backplane. If I cut off the part with holes and flatten it out it might work too. OR get soldered to the board... I think I'll pass on trying that and going with the Al foil unless I dig up something better... Alright - I've got a nice Al pie pan.Last edited by SteveNielsen; 09-14-2015, 10:04 AM.Comment
if the chip is bad then:
http://www.ebay.co.uk/itm/141666259867
and:
http://www.ebay.co.uk/itm/261574745774
Without the chip there is 1053 ohms from Gnd to Out pads where IC2 reg was, so the 2 ohm short is in the chip.
Al foil in 4 layers for a heat shield worked perfectly. The chip came off sliding sideways a bit so I cleaned up the solder pads for it with wick and iron and no solder bridges or damaged pads. This is a first for me; the first smd microchip of this type I have ever tried to remove! Yay!Comment
is the software easy to get? if you go for the ebay chip/programmer.Comment
no mine dosnt either ive just found this though
http://www.mikrocontroller.net/svnbr...ster/Software/
http://www.mikrocontroller.net/topic/248078Last edited by vinceroger69; 09-14-2015, 11:38 AM.Comment
oh yes - cutting edge version!
Attached FilesComment
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by maleksaThe LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...-
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... -
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos - Loading...
