LF-8800 any good?
  • Stefan Payne
    • 1267
    LF-8800 any good?
    So I got anoyed with my ERSA Irons (one older 16W and 1 rahter brutal 150W Soldergun), I decided to get a decent soldering station...
    I'd like to have a desoldering gun, like shown in this video...
    So I took a quick look at what's available here in Germany and I found an LF-8800. Price seems quite reasonable with something under 300 Bucks. And I have the option for a hot air gun.
    So is it any good and worth the money?
    It seems to come with some nice other things...
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: LF-8800 any good?
    Assuming that's a Xytronic LF-8800, would be prudent to stock up with spare parts as well
    If my experience is anything to go by:
    https://www.badcaps.net/forum/showthread.php?t=47615
    essential replacements are almost unavailable when the machine is a little older
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • Stefan Payne
      • 1267
      Unfortunately there isn't much choice here in Germany...
      The other things I've found:
      http://www.amazon.de/AOYUE-Int474A-E...Entlötstation
      BEWARE: Links are in German. But you get the model numbers...
      Still, since I also need a soldering iron...
      And a Hakko FR-300 isn't available in my region (at least I didn't find a shop)...
      • Stefan Payne
        • 1267
        Well, since there ain't no good options, I risked it and ordered it...
        Next month I probably will order a pair of SMD tweezers...
        • Stefan Payne
          • 1267
          Got it, used it a couple of times already.
          The Iron is good. What's inside the box is also pretty nice.
          But I have problems with a jammed desoldering nozzle...
          How do I really use such a thing? Is this a normal thing??
            • 31190
            explain "jammed"
            • Stefan Payne
              • 1267
              The solder gets stuck in that nozzle, most times right before the filter, where the tip is not heated anymore...
                • 31190
                your not holding the button long enough - it should shoot through the nozzle and splash against the back of the catch tube assembly before it sets.
                have you watched the pace video for vac desoldering?
                • Stefan Payne
                  • 1267
                  You mean this video?
                  https://www.youtube.com/watch?v=ULWDrF-JEUk
                  Well, now I have, but nothing really interesting is shown...
                    • 31190
                    i meant his one.
                    https://www.youtube.com/watch?v=e8KRPFOD1RE
                    • Stefan Payne
                      • 1267
                      Thanks, I'll do that later today =)
                      • Stefan Payne
                        • 1267
                        Well, got rid of the clogging problem. Brute force method: Set Iron Temperature to 400° and more...
