Soldering station Pause LED
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 661
    • samsara
    Hi Peeps,
    Have recently acquired a soldering station.
    Seems to operate OK, except that the green pause LED does not appear to function.
    Am assuming that the pause LED indicates when the station is not heating the iron?
    Have let it sit for 5 mins, and the iron reaches the set temp, but the green LED doesn't even blink.
    Tested it with a 3v lithium and it turns on (better with 2 lithiums in series, to give 6V)
    The wires (red and white) from the green LED, plug into the circuit board, along with two other wires that come from the top two pins of the iron socket (black and green)
    Have taken a photo of the circuit board where this connector plugs into. (it's the smaller brown connector)
    Is this looking like a fault in the iron, or a problem with the circuitry?
    • 31091
    Re: Soldering station Pause LED
    it may work with a special stand.
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 661
      • samsara
      Hi again,
      Hope all is going swimingly
      Didn't think of that
      What difference would a stand make?
      Multimeter shows continuity from the metal of the iron to earth.
      And after your suggestion, tried pointing the iron downwards at all angles when the iron had reached the set temperature - but still no green LED light
        • 31091
        some irons from Hakko and JBC for example have optional special stands.
        the stand plugs into the controller, the iron plugs into the stand.
        some stands have a microwsitch on them, some just detect the shaft of the iron against the stand - because it's earthed.
        you should trace the pause wires into the iron handle and see if they actually connect to anything - they may not even be used on the iron plug - only the controller.
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 661
          • samsara
          Thanks bud, will bear that in mind if the following doesn't yield results
          Might have just found it after trying a different combo of wider search terms:
          From www.xytronic.com
          ENERGY SAVER: Automatically powers down after 15 minutes of idling indicated by the Pause LED-saving power while extending tip life.
          So will try it again for longer than 15 minutes
          BTW, Are these tips likey to be legit or lefake?:
          http://www.ebay.com.au/itm/1set-Sold...item1e76333496
            • 31091
            http://sg.rs-online.com/web/p/solder...ories/0255067/
            notice the line
            Features selectable sleep function to prolong tip life and an energy saving automatic shut off function
              • 31091
              probably fake,
              but dont worry about it.
              that design of tip that fits inside the element is very good unlike the old hakko design that slots over the element.
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 661
                • samsara
                Nice.
                Am assuming that lead-free tips are suitable for lead soldering?
                  • 31091
                  yes.
                  btw, clean the tips before you turn the iron off to make them last.
                  it's leaving solder on them that does them in because of the flux.
                  • mariushm
                    • May 2011
                    • 3799
                    @socketa
                    Some stands have a hall effect sensor somewhere close to where the tip of the iron would normally be. When you put the iron in the stand, the sensor would be affected by the metal of the tip and change it's value, so that's how the main soldering station knows you placed the soldering iron in the holder.
                    I have a Pace HW-50 soldering station that has a stand with such a system but it was optional for the hw-50 (the cheapest model in the series) so it's not installed on my stand.
                    By design, if the iron holder has a sensor, my station would bring the temperature down to 100c (from 180-250c) after 30 seconds of "stay in holder" time.
                    Some guy on the internet made an alternative to the Pace design by using a very narrow angle infrared led and an infrared sensor placed on the other side side of the holder. When iron goes in the stand, the tip interrupts the infrared beam and the station detects the soldering iron as inside the stand.
                    It's fairly easy to add something like this to your own station but you do have to know the pinout for your connected, in my case it's easy (ground, 5v, state)
                    @stj
                    The correct way to preserve your iron is to clean the tip after usage (wipe the solder off using chemwipes or some paper handkerchiefs/towels), then apply a new layer of solder to the tip and leave it there. The sacrificial solder prevents the copper in the tip from oxidizing.
                    The most modern fluxes found in regular solder wire (no-clean etc) are not that powerful/corrosive , they won't kill the tips in any reasonable amount of time.
                    When you want to use the iron again, you wait until the iron heats up, clean the old solder that you applied before you finished using the iron last time using a paper towel or something like that (because it's dirty/oxidized etc), wipe the now clean tip on the wet sponge to shock away whatever oxides are still on the tip and quickly apply a bit of fresh solder which would prevent the tip from oxidizing and also make heat transfer between tip and your pins/pads on pcb faster.
                    Then you bring the iron tip to your surface (what you want to solder), touch the iron to the pin or pad or whatever, and bring in the solder wire with built in flux and that solder wire actually solders.
                    See this video at about 1:20 to see what i mean : https://www.youtube.com/watch?v=0SnOW2VdCTI
                    Some of the tips in the series of videos he made are excessive but he teaches a course for avionics that forces him to follow some strict standards.. you can see it almost gets ridiculous when he has to solder a resistor on a pcb : https://www.youtube.com/watch?v=Vynb_HdEIDU
                      • 31091
                      very few tips have exposed copper.
                      btw, that guy should have just used a pyro-sensor from a pir unit.
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • caprider
                        Recommendations of quality soldering station and (separate) hot air station
                        by caprider
                        Hey,
                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                        I now have a TS100 and some soldering irons and looking for some better tools.
                        1. Soldering station, budget around 200-240€
                        JBC BT-2BWA seems to be a good product in the budget.
                        2. Hot air station, budget around 200€
                        Up to now I've found ATTEN ST-862D to be a good option....
                        01-15-2022, 02:05 AM
                      • rmjimenez455@gmail.com
                        Sumsour station 8586D error H-E
                        by rmjimenez455@gmail.com
                        Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                        09-07-2024, 09:33 AM
                      • mkbehbeh
                        KSGER C245 Soldering station PSU 220V only?
                        by mkbehbeh
                        I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                        I am...
                        04-17-2023, 03:11 PM
                      • deep000
                        Looking for a budget hot air soldering station for hobby use
                        by deep000
                        I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
                        Any recommendations for a "good" cheap one that gets the job done?
                        Thanks in advance
                        04-25-2025, 02:29 AM
