Basic waveform math terms
  • japlytic
    • Oct 2005
    • 2086
    On some oscilloscopes, instead of Addition, Subtraction, Multiplication, and Division (or its symbols thereof), the following terms are used instead: Sum, Difference, Product, Ratio.
    Would most with basic mathematics knowledge understand the terms Sum, Difference, Product, and Ratio?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Basic waveform math terms
    Makes sense to an 18 year old
    Well, the answer to an addition statement is called the "sum", the answer of a subtraction statement is called the "difference", and same applies to multiplication ("product"). The division being called ratio makes sense, because it looks like this: "20/5". The ratio of 20 to 5 is the same as 4:1. So there are four 5's in 20. (20 divided by 5 gives you 4 .... four 5's in 20)
    addend+addend=sum
    minuend-subtrahend=difference
    factor*factor=product
    dividend/divisior=quotient
    (Note there are different words that are used sometimes, like "augend+addend=sum", or "multiplicand*multiplier=product")
    I'll come to the conclusion that most people would know it. I know I learned those in school. At least, those who are actually using the 'scope - who presumably are more into engineering - are more likely to know math better.
    -Ben
    Muh-soggy-knee
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Sum, difference, product, quotient is how I was taught. Ratio makes some sense but I've always thought of ratio as an equation involving three values that can be expressed as either a product or a quotient. For example Ohm's Law.
      • redwire
        • Dec 2010
        • 3910
        Most scopes just (for example) add the waveforms, but some can do math like shift one waveform (in time) and then add. I believe it's different terminology between vector and scalar math. A vector has magnitude and direction (angle).
        You can't really add or divide 10V<40° with 5V<184°
        I dislike the math feature because many scopes will clip and bungle the addition without telling you, if there's a DC offset and you move the trace.
        • ShadowAi12
          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
          by ShadowAi12
          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
          • The board enters a "ready to power on" state after plugging in the PSU.
          • Pressing the power button increases power draw.
          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
          Measurements:
          (taken after pressing the power button, while the board is attempting to start)
          • H_SKTOOC#
          06-11-2025, 01:05 PM
        • swofra
          Basic electronic knowledge resources
          by swofra
          Hey all,
          I've got a few XBOX power problems but don't know much about anything concerning electronics troubleshooting outside of replacing caps. Instead of coming on here and wasting people's time being confused when they say check rectifier, transistor, resistor, etc or whatever it may be and then having to ask "what is that?", I wanted to learn and build up a knowledge base first so I'm not completely clueless and can apply the good advice people give without confusing the situation more by not knowing what i am doing.
          Is there a good thread or source, either on this...
          11-07-2023, 06:52 PM
        • ductranvinh
          Graphics card repair, Basic Measurements
          by ductranvinh
          Hi everyone!
          The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
          But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
          Note! This article may or may not be true.
          Measurement: (must have boardview of course)
          Adjust the impedance scale
          12v block
          Measure the 12v fuses, see if they burn out.
          If the fuse blows, the risk of burning the pcb is...
          06-29-2022, 05:12 PM
        • tybul
          Echips Basic Slim 14"
          by tybul
          The laptop turns on, but there is no image. Motherboard SA116L_VF4
          Does anyone have a working BIOS or please fix the file in the attachment...
          09-19-2023, 10:41 AM
        • MuertoGB
          Mac EFI Toolkit
          by MuertoGB
          Hi all. I'm Muerto, the creator of SMCTool/SMCFT. I thought this would be a good home for discussion regarding an open source pet project I've been working on that aims in easing Mac BIOS/UEFI analysis and editing. It is currently developed for Windows, however is Wine compatible based on my own testing, and feedback from others. Project available on Github, there is also a manual with basic usage instructions.
          In terms of editing, it can export and replace the Fsys Store, edit the serial number + hwc, clean NVRAM stores, export and replace the ME Region in a limited...
          09-15-2023, 05:45 PM
