Mastech ms8229
  • Kawooa
    • Apr 2015
    • 16
    Re: Mastech ms8229
    Originally posted by retiredcaps
    Try interchaning the bottom 4 contacts with the top 4 and see if the volts and amps functionality work? The reason for moving them around is perhaps one of the contacts is bad or malformed? If moving them around results in different behavior that tells us something too.
    I did. that was how I got the volts but lost the other functions. I can try moving contacts into different spots and see what that does after I can get to it.
    Make sense? What fun is there in making sense?- Discord
    • Agent24
      I see dead caps
      • Oct 2007
      • 4981
      • New Zealand
      Re: Mastech ms8229
      So it sounds like the contacts on the knob are probably bad. Maybe they have worn down and are not making proper contact with the PCB anymore?
      -David VanHorn
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Mastech ms8229
        If that is the case, the cheap/free Harbor Freight $2.99 830 like DMMs can be used as a donor?
        Modemhead has some pictures that show the contacts of these cheap meters.
        http://mrmodemhead.com/blog/gallery/cen-tech-92020-dmm/
        Alternatively, you can try to bend or see if all the contacts are the correct height at the peak point?
        --- begin sig file ---
        --- end sig file ---
        • Agent24
          I see dead caps
          • Oct 2007
          • 4981
          • New Zealand
          Re: Mastech ms8229
          If they fit, I suppose so.
          -David VanHorn
            • 31094
            Re: Mastech ms8229
            i cant see how those contacts could be bad,
            i would take closer look at the switch board & meter board.
            i would be checking the through-hole plating etc looking for bad tracks.
            one thing i can see, the plastic part has spaces for more contacts.
            are any missing or in the wrong location?
            • Kawooa
              • Apr 2015
              • 16
              Re: Mastech ms8229
              I don't know if they are missing some or in wrong position. I did move them around which is how I got the volts back but lost the other ranges was because one contact was off by barely anything. I can move them but I dont know how much I could do. Also I don't think they are worn down. I used it for only a couple months before it died.
              • Kawooa
                • Apr 2015
                • 16
                Re: Mastech ms8229
                Sorry I took so long. Had some other stuff I was too focused on. I did move the contacts but instead of the top four and bottom four as suggested, I had moved the bottom with the one above it and so on. That was how the contacts got off and it changed it to where the volts were back but every other range was gone until one poster posted a image and I fixed that.
                  HP Compaq Pro 6300 Compaq Pro 6300 i5-3570 Specification for Upgrade or Repair
                  This specification for the HP Compaq Pro 6300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro 6300 boardview and Compaq Pro 6300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-12-2024, 03:28 PM
                  HP Compaq Pro 6300 Compaq Pro 6000 i5-3470 Specification for Upgrade or Repair
