Short to ground
  • newtothis
    • Mar 2013
    • 1556
    • england
    Short to ground
    OK so haven't really dealt with many shorts so wondering if someone can explain a couple of things.
    Have a board which I am guessing has a short to ground... If I attach my black probe to the power input ground and red to a lot of components (both sides and even with component removed both pads) my multimeter beeps to tell me there is continuity.
    Is this a short to ground?
    Re: Short to ground
    Power input ground, you mean safety GND or circuit GND, primary circuit or secondary circuit?
    Using beep mode, depend on the meter, some will beep with resistance as high as 100 Ohms.
    I would use Ohm mode. The dead short is <1 Ohm, other that consider as shorts can be >1 Ohms depends on the circuit. You also have to consider the circuit, for example the output of the power supply may have bleeder resistor, or dummy load to keep the power supply steady when there is no load connected, the value can be 100 Ohms or less depends on the Voltage and how fast they want to discharge the caps.
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: Short to ground
      Its a graphics card I am dealing with.
      Have my black on the pin with blue arrow.
      Red any any components in red and blue areas + more give continuous beep.
      Components in blue areas will give 0 ohms across them.
      Even removing components and checking across their own pads give 0 ohms
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: Short to ground
        bump
        • selldoor
          Slow Learner
          • 7870
          Re: Short to ground
          Blue things are inductors? so should read as short.
          Are you sure the pin you refer to is not a ground pin?
          Have you tested that pin to say the bracket at the other end.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Re: Short to ground
            PCI-E Connector so all blacks are ground and all yellow are 12v.
            But even after removing a component should there be continuity to the ground on both pads?
            • selldoor
              Slow Learner
              • 7870
              Re: Short to ground
              By components do you mean inductors (L on board designator) continuity from pads - perhaps but short to ground unlikely as budm says use and quote ohms.
              Did you test - pin to bracket?
              • newtothis
                • Mar 2013
                • 1556
                • england
                Re: Short to ground
                Pin to bracket is 0 ohms
                Pin to both pads (not inductors) gives 0 ohms
                • selldoor
                  Slow Learner
                  • 7870
                  Re: Short to ground
                  I may have this wrong but from what I have seen the top four pins are Ground.
                  Is that pin a top pin ie the edge nearest the clip. Also one of the bottom pins might be a sense pin which is also ground
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Re: Short to ground
                    Seems it is ground yes
                      Re: Short to ground
                      I see 7 black filter caps with + symbol on one end, what resistance between the two legs of those caps do get? Any one of them show <1 Ohm?
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        Re: Short to ground
                        By board is slightly different.... Only a 3 of them. All check fine
                          Re: Short to ground
                          OK, you should then upload your board so there will be no confusion on which parts of the board we are trying to locate.
                          • sasser
                            • Dec 2012
                            • 364
                            • Malaysia
                            Re: Short to ground
                            Im also want ask masta here howto check short to ground. Are that means when measure resistance ohm is set to digital multimeter with black probe at gnd and red probe at positif side component? And what value ohm if short? > 1ohm or below or can be zero?
