DSO201/DSO203 firmware for mains analysis?
  • japlytic
    • Oct 2005
    • 2086
    I am curious if someone would be able to write a custom firmware for the DSO201/DSO203 mini oscilloscope so it can be used as a a mains power analyser (with appropriate divider probes), with the following features:
    * Measure frequency and voltage as well as harmonics and noise with or without a current clamp attachment (current clamp can be configured) - power factor can be measured with a current clamp attachment (again, user configurable).
    * Record as many harmonics as possible (ideally, 50 at least) in a table with THD and noise and graphically.
    * Measure mains frequency deviation against a user set frequency.
    * Log to memory card on power disturbances (power failure, sag, surge, undervoltage, overvoltage, transients, line noise, frequency deviation, harmonic distortion etc. with user-configurable thresholds) and/or during preset periods of the day of the parameters mentioned above.
  • Longbow
    • Jun 2011
    • 623
    Re: DSO201/DSO203 firmware for mains analysis?
    Your product awaits you at Fluke Industrial test equipment division.
    Is it plugged in?
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • gurj1979
      Ubiquiti firmware help. US-8-150W POE
      by gurj1979
      Hi guys.
      I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
      Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
      So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
      Got New chip and writes good.
      THE PROBLEM...
      It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
      Does anyone have a Good Firmware I can have?...
      07-22-2024, 05:13 PM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • sikocan
      NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
      by sikocan
      I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
      However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
      01-11-2024, 01:47 AM
