UNI-T UTP3315TFL-II (2025) Linear PSU review
  • harp
    • Jun 2022
    • 704
    • Planet Earth
    Review of UNI-T UTP3315TFL-II (2025) 30V 5A linear PSU A laboratory power supply is one of the essential devices a DIY hobbyist should have, whether built or purchased. The internet is full of schematics from experienced electronics engineers showing high-quality power supplies with various features that differ from commercial products. In my case, I also used various "adapters" — power supplies from different devices such as mobile phones, laptops, and similar — sometimes combined with Chinese voltage and current control modules. While doing that, I was also gathering schematics and knowledge to better understand what to choose from the available options that would meet my expectations. In the meantime, the opportunity arose to buy a commercial product... but which one to choose? What I already knew (from watching videos by experienced electronics repair engineers) is that it should preferably be "linear". This means it operates on an analog principle, not a digital one. Linear power supplies are generally easier to repair if something burns out inside, simpler in design, more robust, and usually do not include various "safety" limitations that can interfere with the main purpose — delivering the set current even into a short circuit. The core of linear power supplies is a large iron transformer, which is quite heavy; for a 30V 5A unit it is around 4 kg. And it is well known that Chinese manufacturers would gladly make better use of those 4 kg of iron and copper... Switch-mode power supplies (SMPS) usually come with many buttons, and it takes more time and steps to set the desired values. Once configured, they can store presets. Of course, there are also SMPS units that can deliver the set current into a short circuit, but you should always verify that before purchase. I believe switch-mode supplies can be very practical for people who frequently design on breadboards and experiment with electronics. They are lightweight — around 1.5 kg including the case — and this is often advertised as a positive feature ("look, it's not heavy!"), even while the product is labeled as a LINEAR lab power supply... In terms of form factor, there are those "box-shaped" generic power supplies that used to all be linear and the cheapest option. Sorin bought one of those for 50 dollars a few years ago... but today, prices for linear supplies have increased significantly. What you should know is that in such "generic box" power supplies, you will mostly find switch-mode designs today, and physically there is no way to fit a 60V/5A or even 30V/10A linear supply inside. With such devices, you never really know what is inside, even if it says 30V/5A on the label, because the brand name often exists for only a year before changing. Chinese manufacturers are least concerned with specification accuracy, and you can often see simple copy-paste specifications everywhere. That is why I chose the UNI-T brand, which has been present for a long time, and whose internal design is more or less known — or at least more trustworthy, although even that can change with ongoing development. www.youtube.com/watch?v=yvCeTv3a0Ac UNI-T UTP3315TFL-II (2025) Linear Power Supply 30V 5A Review Sequa coupling caps The power supply arrived undamaged, and upon first power-up I heard exactly what I expected... the fan runs at full speed all the time. Do not be misled by the "low noise" label and the speaker icon on the packaging — this is how Chinese manufacturers translate "low ripple", which refers to low output voltage ripple, a typical characteristic of linear power supplies. I immediately started designing a small smart fan controller (a truly smart one), and today that project is finished with great satisfaction. It now works exactly as intended: the fan runs at minimum speed up to 30°C (virtually silent), and then increases its speed proportionally (linearly) as the heatsink temperature rises, reaching full speed at 50°C. The result is cooling that is truly proportional to the actual need at any given moment, without unnecessary noise. As soon as the load decreases or stops, the fan quickly adapts to the new conditions... a pleasure to use. Aside from that, the power supply performs well and I am satisfied with it. Both voltage and current can be easily adjusted using coarse and fine potentiometers, which move smoothly. The display is clearly visible from different angles and is not overly bright. The only drawback is the very small heatsink, which definitely needs to be replaced if you plan to use the unit at higher voltages and currents. Fortunately, there is enough space inside the enclosure for a proper heatsink — which will be the next project
  • harp
    • Jun 2022
    • 704
    • Planet Earth
    Sorry, I forgot that badcaps has problem with formatting...
      • 31831
      i was about to say, thats a wall of text!
      • harp
        • Jun 2022
        • 704
        • Planet Earth
        Yes, the problem is, that I see text formatted in quick edit box... but as soon I posted, it eat all formatting and add some garbage after hash sign... I cant edit later. But, who cares that "forum" works only in new browser, the forum, aka news group, bare text, point on sharing information, knowledge... I posted the same article on Sorin forum, and on eevblog forum: https://www.eevblog.com/forum/testge...ar-psu-review/ ... but from some reason I can not visit sorins forum anymore... so sad that tehnology is fall apart...
          • 31831
          gotta love how a ban is listed as an error!
          • harp
            • Jun 2022
            • 704
            • Planet Earth
            That message is poped up after migration from .com to .co.uk domain I think, sorin announced to know about forum problem, so I wait... message about ban is showing at the time now, but ban is set automaticaly for unknown reason. I was not noty
            • domix
              LG Air Conditioner AC unit bypass
              by domix
              i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
              Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
              how can i bypass this :/
              I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
              11-25-2025, 02:54 PM
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • Boardview and Schematic Bot
              Y9000P 2025 Lenovo Legion Pro 7i Gen 9 (2025)
              Y9000P 2025 Lenovo Legion Pro 7i Gen 9 (2025)...
              01-29-2026, 03:51 AM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
