852D close soldering station heating element replacement issue
  • GraphicMan
    • Aug 2018
    • 141
    • Egypt
    Hello guys
    I have got the A1321 heating element, i think there was a mistake in the listing on aliexpress as it states it is compatible with my soldering station but the problem is that i found it is not, the original and burnt heater have a thermocouple sensor (polarity matters) and the new one have a themistor sensor (resistance output, no polarity) the heater is compatible, the sensor is not
    i have seen a video where someone did use it though as a replacement after adding a resistor on perhaps one of the inside pcb's of the station, i would like to make sure if that is possible (i wish i can make this mod to make it work)
    attached are the pics for the old heating element before desoldering, as well as the new heating element
    is there anyone can guide me through ?
    thanks
  • harp
    • Jun 2022
    • 685
    • Planet Earth
    I am interesting... what is resistance of original sensor vs new one?
    What happens when a new part is installed—how does it behave?
    • GraphicMan
      • Aug 2018
      • 141
      • Egypt
      I have not made that mod, here is the link
      https://www.youtube.com/watch?v=pG0xtk9URAI
      but i am not sure, that is why i am asking perhaps my soldering station is also different than his
      I dont understand how adding a resistor can make such a conversion! I wish someone here can enlighten us
      • harp
        • Jun 2022
        • 685
        • Planet Earth
        A thermocouple sensor is made of two wires of different materials welded together at the tip. When the tip is heated, a small voltage is generated at the wire ends due to the potential difference between the materials used. This voltage is then amplified and processed.
        With a thermistor, a special material is used that changes its resistance depending on temperature (and it always has a significant resistance), but it does not generate voltage. The video describes a way to obtain the desired voltage at the sensor (required by the controller) by using a voltage divider made of two resistors - one is the sensor itself, and the other must be added.
        With a thermocouple sensor, the resistance is very low; it is simply a bare wire made of two different materials, and its resistance does not change significantly when heated.
        I have 852D+ and sensor has 52 ohm on one side of connector, heater about 4 ohm at other side, and the middle pins seems shorted (or it is thermocouple sensor)
        • GraphicMan
          • Aug 2018
          • 141
          • Egypt
          yes i understand how both work, the question is , where did he get the initial voltage to begin with ?
          if i open the unit can you help me out make it?
          • harp
            • Jun 2022
            • 685
            • Planet Earth
            Maybe he measure value from original element... while power on. Or experimental, try and error...
            Many people may have the desire to help, but in reality, you are on your own — do not attempt a repair until you fully understand what you are doing and how you are going to achieve it.”
            • Agent24
              I see dead caps
              • Oct 2007
              • 5365
              • New Zealand
              • Electronics and computer repair
              I had the same problem when replacing a heater like this.
              There are several and not all are the same.
              But most sellers don't know the difference.
              What should work for you is the A1322 like this https://www.ebay.com/itm/206178916590
              I think that is the style I got for mine. (Duratech Hakko 936 Clone)
              Although the shape of the element base for yours looks more like this one: https://www.ebay.com/itm/182138169856
              I wouldn't bother trying to adapt the different element, it will be a right pain and I don't think the heater will fit in your handle anyway as the wiring is too thick.
              The correct heater is cheap enough.
              -David VanHorn
              • GraphicMan
                • Aug 2018
                • 141
                • Egypt
                i agree about the base end shape style, but i think it is not a problem because i have that from the original one, the soldering iron was barely used and i always use it at a very very low temps compared to what it can do, so i am assuming these cheap heating elements are already poorly made and i assume the replacements will be identical! but on the other hand the A1321 seems like proper ones and far superior to them, i wish i can made the mod and that it is not very difficult and durable, i want to give it a shot specially if it is reversible , i dont think that the wire are a problem it seems to fit
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5365
                  • New Zealand
                  Well the one I used has been working for years and even the original was still working, just the ceramic core was cracked so I replaced it as preventative maintenance. Sounds like you got unlucky with yours maybe.
                  -David VanHorn
                  • GraphicMan
                    • Aug 2018
                    • 141
                    • Egypt
                    very possibly, can you share a link for the station that you have?
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5365
                      • New Zealand
                      Sorry, no, it's not made anymore. It's a Hakko 936 clone branded for a local electronics chain.
                      -David VanHorn
                        • 31771
                        cant you just swap the sensors over?
                        • GraphicMan
                          • Aug 2018
                          • 141
                          • Egypt
                          it is not available here, consider it a challenge/adventure
                          also i got 5 of them, so it will be nice if i can use them for the future, also these newer ones heat up much faster and suppose to be of a much higher quality
                            • 31771
                            i mean use the original sensor from the broken heater in the new heater
                            • GraphicMan
                              • Aug 2018
                              • 141
                              • Egypt
                              oh sorry i missunderstood you, yes i have been thinking a LOT about that, the sensor and i think they are all the same are built inside the heater, it is a ceramic thin rod with 3 tiny holes! 2 holes for the sensor leads and the third one is for one of the heating coil (the start of it) then the coil is wrapped around that ceramic rod, then another ceramic tube is over covering all that, now i have the old sensor yes with its rod, i did try it as a test after sticking it to the new heater and soldering all the leads to the pcb, that worked fine as expected, new heater to the board with old sensor, new sensor is not wired, but the problem is that there is no room for that ceramic rod that have the sensor, and if i break the ceramic rod it will not be possible to use the sensor because its leads will short from the steel housing as well as the tip tube, it is possible to wrap the old sensor with its rod outside the top but even with that i need to drill a hole to pass its leads to the pcb, i think but i am not sure that the best method is to use the new sensor but i have no idea about the amount of work needed to modify the station for that, i need help with that
                                • 31771
                                i would start by drawing a schematic of the sensor circuit.
                                then compare it to some other schematics.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5365
                                  • New Zealand
                                  Here's the description of that iron from the Jaycar 2008 catalogue CD-ROM.
                                  It also claims to be a ceramic heater, but it's not, the cracked heater I have clearly has a spiral-wound wire heater inside.
                                  I still use that station for a lot of basic work but it's not the most powerful.
                                  I also built myself a Hakko T12 style station from an open source design.
                                  -David VanHorn
                                  • GraphicMan
                                    • Aug 2018
                                    • 141
                                    • Egypt
                                    thanks a lot for the share , btw is there a way to know the real type of the heating element without cracking it?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5365
                                      • New Zealand
                                      I think you can tell by looking at it, from what I gather (but I may be wrong!) the true ceramic ones seem to have a vague outline of two distinct darker areas inside the heater core, while this is not visible on the other type, it's all just solid white. At least the comparison between my original heater and the incorrect (for me) A1321 heater shows this difference.
                                      See the attached photo, you can see the different dark areas.
                                      -David VanHorn
                                        • 31771
Name:	852D++ Schematic.jpg
ID:	3879893 i found this in my document-stash!
                                        (this is why you save everything you see!!!)
                                        • EasyGoing1
                                          The best way to drive a heating element?
                                          by EasyGoing1
                                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                          This is the general setup that I have now.
                                          This is what the...
                                          01-25-2023, 11:29 AM
                                          07-01-2024, 06:34 AM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
                                        • CapLeaker
                                          Aifen A9HD C245 soldering station?
                                          by CapLeaker
                                          Anyone tried or has the Aifen A9HD with the C245 handle and T245 tips? Need another soldering station. Thought I am gonna try something else as the Aixun T3A with C245 handle.
                                          04-24-2026, 03:06 PM
                                        • jm1234
                                          Soldering tips N9-XXX for ZD-8916
                                          by jm1234
                                          I have soldering station ZD-8916 and I only see like 6 different soldering tips being offered, eg. by tme: https://www.tme.eu/ie/en/details/zd-...er-peak/n9-26/
                                          Very limited variety, I'm missing a chisel ones, it just doesn't exist.
                                          I thought to myself everything is available in china, but they don't seem to be using the same nomenclature. Searching in aliexpress or temu for N9 tip doesn't find anything.
                                          Is there perhaps equivalent type to N9 I should be searching for?
                                          Or is my soldering station that weird and I just shot myself into a foot?...
                                          12-02-2025, 05:45 AM
