Hello, the EEPROM chip in the hot air station shown in the picture is faulty. Where can I find the EEPROM software for this device?
I need Class 968 EEPROM firmware.
Does the EEPROM hold program code or calibration data?
I would have thought the program would be in the microcontroller anyway.
Makes me wonder if it's a better choice to get an analogue station with no microcontroller at all..."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
the eeprom just stores the temperature and maybe some cal offsets.
this is an interesting read:
https://www.eevblog.com/forum/review...stom-firmware/
I'm only about halfway through but definitely a good read! Seems like a lot of those cheap stations could do with that upgrade.the eeprom just stores the temperature and maybe some cal offsets.
https://www.eevblog.com/forum/review...stom-firmware/"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
It looks like some models on AliExpress already have similar displays.
I am tempted to get a basic 7-segment one and modify it, my hot air station is only 320 watts, these are about twice that, it would seem."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
lol, oh no....
Makes sense, is there any advantage to the higher wattage stations then? Just faster heat-up time?"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Ahh yeah.. silly me... which I suppose would be good for large BGA chips like GPU cores etc"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
Hello, thank you to everyone who responded. The resistance wires of my blower soldering iron short-circuited, shattering and damaging the transformer and motherboard. The EEPROM integrated circuit looks fine, but it's gone when I touch its pins. What can I do? Buying a new one isn't the issue; I enjoy repairing things.Comment
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by karloxHello everyone,
I have an Epson PowerLite S18+ projector in the workshop showing signs of a firmware fault. I’ve checked all voltage lines and signal paths, and everything seems within normal range.
Here’s the issue: when the power cable is connected, the power LED immediately turns blue even though the projector doesn’t start. When powered on, the fans run but the lamp never ignites. After a few minutes, both the temperature and lamp indicators turn red.
I’m attaching the backup I read from the IC in case it’s useful for analysis or comparison.
If anyone...10-16-2025, 07:48 PM -
by BruggefanHi all
I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
What happened:
- Did BMC firmware update in 2020
- Doing this, my MAC adresses were cleared from my nics
- Added MAC adresses with an eeupdate tool
Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
Since then, both my 10Gbit and my 1Gbit NICs stopped working.
The amber led on the NICs is solid on, no matter...12-18-2025, 03:12 AM -
by NSkyLabHello everyone, I described the symptoms and measurements here
It seems I tried everything, my last idea is that the eeprom or firmware (or both) may be corrupt.
I'm not able to find eeprom and firmware dumps in open sources.
Hoping someone here has access to closed forums or manufacturer's service center resources and can help get those dumps?
01-20-2023, 12:29 PM -
by jrbrassowHello all,
I am attempting to convert an 86-inch commercial display, manufactured by TPV, back into a standard, fully functional TV/monitor. The display is currently running corporate/embedded firmware that prevents standard operation.
The primary goal is to find the original or a compatible "public" (non-corporate) firmware file to flash the mainboard and restore normal HDMI input functionality. 1. Display Identification & Hardware Details- Suspected Origin: TPV / Philips Professional Q-Line or P-Line series.
- Panel HWID (from Windows): MONITOR\MGF86
- Loading...
