Quecoo T12-958 soldering iron tip not grounded
  • lcdcaps1
    • Oct 2011
    • 360
    Hi
    I have a Quecoo T12-958 soldering iron and have noticed the soldering iron tip is not grounded
    i dont want to use it like this
    I only found out because the chassis ground wire from the ground lug / bannana socket came off
    how can I ground the soldering iron tip
    What I thought of doing is soldering a wire from the ground leg on the soldering iron tip connector to the ground lug
    Would this be ok
    There is a earth wire from the PSU to control board but its not connected to anything.
    • 31821
    you can ground the tip,
    but a resistor is better to limit the current if you touch a charged capacitor or forget to unplug what your soldering !!
    maybe 220k or 470k.
    enough to disipate static but if you touched mains it will only allow a few mA to pass
    • lcdcaps1
      • Oct 2011
      • 360
      maybe 220k or 470k.
      Thanks for the reply
      but what would be the best way to do it
      Also i see that the barrel jack is not connected to the ground lug
      Can i solder the ground from the barrel jack to the ground lug
        • 31821
        the ground pin on the power inlet should really be connectedto the ground jack through a resistor to protect the user from cable/building-wiring faults.
        the iron itself as i said, direct or through a resistor depending on how you use the iron.
        if your making stuff or repairing low voltage low current devices then ground it if you want,
        if your repairing things like psu's then i recommend a resistor to limit the chances of sparks or damage.
          • 31821
          take out the psu board with the back panel attached, see where the inlet earth pin goes.
          • lcdcaps1
            • Oct 2011
            • 360
            Thanks for the tip
            I connected to the front connector pin
