Please tell me where I'm going wrong with hot air!
  • G-Gamer
    Repair Tech /s
    • Nov 2025
    • 8
    • United Kingdom
    So I'm trying to get into micro soldering, repairing tech etc.
    I bought a load of equipment, The YIHUA 853D 2-in-1 station, 1080p Microscope with 10", I do not have low-melt or leaded solder yet, I have tried flux 'paste' in a tube, very liquidy seems to blow away, I've tried flux paste in a tub, still no luck.
    I have tried 3 different boards, a router, an Xbox One Fat and now a Pi400, none show ANY signs of melting solder, components don't budge.
    My method:
    Preheat board with hot air (Small nozzle as it's directed, as I'm told) at 250c
    Apply flux to component
    Hit with hot air at 350,370,400 - nothing budges.
    I know about heat transfer to larger components and the board being a big heatsink but I'm supposedly doing everything right bar the low-melt, but that shouldn't make a difference that much if I'm using the above temps?
    I have ordered some low melt solder to try lower the temp, but I need to figure this out, everyone makes it look so simple so I'm unsure where I'm going wrong, I have tried HDMI, USB, random small chips and caps, nothing ever moves...! I have tried using my iron and wick to remove the legs but that didn't help either Click image for larger version  Name:	image.png Views:	0 Size:	8.44 MB ID:	3764295Click image for larger version  Name:	image.png Views:	0 Size:	8.23 MB ID:	3764296​​
  • m1ch43lzm
    • Mar 2019
    • 1029
    • Peru
    Don't use very small nozzle 3mm, try with 6-8mm nozzle, keep practicing on scrap boards, you don't want to cook the parts by heating them for long time, it also depends what components you want to remove
    Also the distance from the nozzle to the board matters, not only the temperature/air flow, try 430-450C; it also depends on how powerful is the heater in your hot air station
    • G-Gamer
      Repair Tech /s
      • Nov 2025
      • 8
      • United Kingdom
      I have the fan speed on 1/8 and it seems to just blow all the solder away
      just takes the life out of me I’ve been trying to just remove a component for 3 days straight, I figured unleaded solder melts at 370 with my iron so thought that would be a good target for hot air
      • m1ch43lzm
        • Mar 2019
        • 1029
        • Peru
        HDMI and full size USB connectors of course require more temp and a bigger nozzle, try with small resistors, capacitors, ICs first
        Temperature at the PCB surface is lower than the temp you set in the hot air station, try 450 as a starting point, it also varies with distance, try getting closer, less than 1cm
        On a smaller/thinner PCB like a phone or tablet it will take less temp for the solder to melt
        And also get a roll of leaded 63/37 0.4mm solder
        • chth96
          Is it good to use chemistronic flux off es835b for flux remover?
          by chth96
          I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
          Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
          11-17-2023, 07:25 AM
          Multifix 425-01 and 450-01 Rework Flux Datasheet
          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
          - No Clean Formulations
          - Low residue
          - Range of activity to deal with different component solderability
          - Halide free
          - Suitable for dispensing
          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
          Both products are supplied in syringes or cartridges for application by dispensing....
          10-07-2024, 06:02 AM
        • evilkitty
          Flux causing high resistance short?
          by evilkitty
          Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
          Temp is on the left humidity is on the right
          i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
          The pin out looking down from the top is (note this is common cathode)...
          07-17-2024, 09:38 AM
        • chth96
          How can I remove flux with the smallest rubbing?
          by chth96
          I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
          Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
          Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
          Is there any way to remove flux with the smallest rubbing or without any rubbing?
          Any reply would be appreciated.
          11-24-2023, 05:22 PM
        • aed040
          Tips when soldering U6960/TPS62180
          by aed040
          I am trying to fix my macbook.
          Can you give me some tips when replacing the U6960 chip.
          What Hotair temp and fan speed do you use?
          How long do you usually wait before you can remove a chip? Ive been watching repair videos and they can easily remove a chip after a few seconds but I've been heating the part on a test board for almost a minute and it wont budge.
          Does a really good flux help in melting the solder? I am not sure if my amtech flux is fake that is why its taking a long time.
          The flux is also being blown away from the...
          11-25-2022, 06:18 AM
