Ammeter woes
  • c_hegge
    • Sep 2009
    • 5219
    Ammeter woes
    OK, now that Kiriakos is gone, I think we can safely talk about cheap(er) meters.
    Basically, I've been experimenting with a few digital ammeters on the load tester. The last one I've tried was one of these - http://www.amazon.com/Watts-Meter-An.../dp/B001B6N2WK. It works great at 12V. With a 5ohm (2.4A) load, it reads 2.38A - probably nothing that can't be explained by small losses in the wires and some tolerance in the resistors.
    on the 3.3V rail, though, it's not as accurate - with a 0.33ohm (9.7A once you factor in the vreg) Load, it reads 8.3A - off by 1.4A (and yes, it is being powered by an external 12V supply).
    So, here's the question - what would be a decent panel mount ammeter to use that offers reasonable accuracy at low voltages and can measure up to the 35A my load tester is capable of pulling on the 3.3V rail?
    I was thinking about using these - http://au.element14.com/murata-power...ter/dp/1339334, as they are intended to work with a separate power supply to the one which is powering the measured load. However, 8V is listed as the minimum supply voltage. Would they work accurately when measuring lower voltages if they were powered by a higher voltage (like 12V)?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Ammeter woes
    aww, i missed Kiriakos getting the boot? where was the thread that it happened?
    as for the meters i don't see why that panel mount wouldn't be accurate.
    Follow the white rabbit.
    • c_hegge
      • Sep 2009
      • 5219
      Re: Ammeter woes
      It was here - https://www.badcaps.net/forum/showth...959#post467959
      I don't know either. It just seems to have some trouble with low voltages
      • AJ847.63e
        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
        by AJ847.63e
        Hi Folks,
        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
        05-06-2025, 10:37 PM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
        HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
        This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
        09-06-2024, 10:56 AM
        HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
        This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
        HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
        This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
