Basic question about resistor
  • homerclone
    • Jan 2014
    • 53
    • uk
    Hi
    I want to test a 1004 smd resistor with a multimeter if I right this is a 1M ohm resistor. My multimeter has a 2M ohm setting. now my question is my multimeter tests it at 0.045 on the 2M ohm setting is it a bad resistor.
    Sorry just getting myself confused
    Mark
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Basic question about resistor
    In circuit can give a low measurement depending on other components connected to it.
    • homerclone
      • Jan 2014
      • 53
      • uk
      ok toke it out of circuit it now reads .998 so must be ok thanks for your time :-)
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        1M, it should read 1 on the 2M scale of your meter.
        the 4 digit code says 100 x 10^4 = 1,000,000
          So it shows 998KOhms(0.998M Ohms), for 5% resistor, then it is OK.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Our posts crossed. 0.998M is good.
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              by mikey5791
              Hi to all forum members,
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • chth96
              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
              by chth96
              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
              Since then, This AC/DC adaptor have been out of order.
              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
              And Is there any possibility that it will suddenly explode as well as to be out...
              12-03-2023, 04:40 AM
            • badcap111
              Xiaomi mi 9T missing resistor
              by badcap111
              Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
              I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
              Is...
              08-07-2023, 10:42 AM
