Blue Ring Tester Error???
  • PC@live
    • Mar 2013
    • 24
    • Italy
    Hi all, looking at the diagram of the testers, I noticed a mistake???
    The Q1 = 2N3904 transistors in the "Parts List" is an NPN.
    However, the schema is connected to +, so it should be a PNP??? (Perhaps 2N3906???)
    If it is a write error (2N3904 transistors instead of 2N3906) then Q2 and Q3 are PNP???
    If someone can explain to me, if there is an error.
    Thank you so much who can help me to understand Yours
  • Radio Fox
    • Jan 2010
    • 281
    Re: Blue Ring Tester Error???
    The collector of Q1 connects to the +ve supply which is correct for an NPN transistor.
    http://electronicsclub.info/transistorcircuits.htm
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
    • PC@live
      • Mar 2013
      • 24
      • Italy
      Thanks a lot.
      The question I had come because the Tester LOPT/FBT, Q1 was a PNP.
      Greetings
        It is shown as PNP per diagram that I have, it is also indicated as PNP in the BOM.
        The Emitter is connected to the B+, it is setup as a simple amplifier to drive low Z load.
        Do you have your diagram?
        The later version has 3 transistors, all NPN.
        • PC@live
          • Mar 2013
          • 24
          • Italy
          Yes, I have both the diagrams.
          In fact Blue R.T. it seemed strange that the transistor Q1 was an NPN.
          Thank you very much
          Greetings
          • Radio Fox
            • Jan 2010
            • 281
            It looks like the Blue ring tester has been modified/improved since the first version of the LOPT/FBT meter.
            • tmiha71
              • Apr 2010
              • 130
              @Radio Fox
              The page you posted is pretty messy. Heading is Transistor circuits, and it speaks of Bipolar-Junction Transistor, commonly named BJT. To be more specific it speaks of “common emitter” circuits. And this is, only, partly true - page speaks of BJT as switch, and probably, if you follow advices from page you WILL burn BJT.
              Page lacks basic things, and can be recommended as funny (practicing) page about BJTs as switches (be carefull, if wrong things are learned, much more time is needed to learn things right). For any serious speak/work, only books by Jacob Millman, or books which references Mr. Jacob Millman books, should be recommended...
              And yes it takes time to read books, but it's worth...
              Probably Wikipedia should be recommended, at first, if web is source of information, but I like books...
              • Radio Fox
                • Jan 2010
                • 281
                The only reason I linked to that page was to show how a NPN transistor should be connected with reference to the supply. It was to show PC@live that the Blue Ring Tester circuit diagram was correct.
                I think that link shows the basics of how a bipolar transistor works pretty clearly for different types of use.
                I doubt that Jacob Millman is the only author who knows how transistors work!
                • tmiha71
                  • Apr 2010
                  • 130
                  Mr. Jacob Millman, is authority, one of the pioneers of solid electronics/microelectronics, and I will have doubts in any book which omits his work/lectures.
                  That link shows how to use BJT as switch, and only as a concept (idea, as you said - basic wiring diagram). No other types of transistor circuits (usage?), and there are few more... To emphasize - title of the page IS misleading... And (that) page deserves pretty decent rewrite/redesign...
                  Yiiek, I am repeating myself.
                    "page speaks of BJT as switch, and probably, if you follow advices from page you WILL burn BJT.'
                    Can you please clarify bu that transistor will burn? It is used as load sink for the load.
                    • Radio Fox
                      • Jan 2010
                      • 281
                      If you are taking a Ph.D. course in electronics, then perhaps works by Jacob Millman are recommended reading, but that's not what we are talking about here.
                      We are talking about a basic transistor circuit. To say that you would have doubts about anyone, other than Jacob Millman, describing how the basics of a transistor works is absurd! There are hundreds of thousands of people around the world who could correctly describe transistor basics.
                      To dismiss anyone else's work is very short-sighted!
                      I agree that there are omissions from that page I linked to (there should have been a linear amplifier circuit).
                      • tmiha71
                        • Apr 2010
                        • 130
                        Page lacks any information about dissipated power... Minimum what should be there, is - max. allowed power dissipation (package dependent)... And not knowing that leads to fried BJT :-))
                        Introduces saturation, and yet neglects it ( saturation voltage is low /page says/, it's not, it is specified in data sheet of device).
                        There's no info about base losses, Ib x Ube...
                        There's no info about switching losses (in some occasions they are dominant, or are they always dominant, can't remember, must check, don't have any Millman book, but have few which do reference his books for further/detailed information )...
                        There's no info about switching time (does have impact on switching losses, less time leads to lower losses)...
                        At first, wikipedia should be recommended (didn't checked if there is any word about bjt's), more people reads it, and error/misconception will be “pretty fast” corrected (hopefully)...
                        Sorry for going OT...
                        PS. (for sure, on that page, there are a few more "half" informations, like Rce, like 5 x hFE... and a VERY GOOD book should be consulted to correct all things)...
                          If you want to do actual design of the circuits then you will need more info to meet your design requirement, basic info is just that, simple term just to explain how it works.
                          • tmiha71
                            • Apr 2010
                            • 130
                            @budm
                            page is a mess of information, any book will do better than that page.
                            I'm tired of defending books from web-based information (and web did brought, at the moment, only ONE advantage, and that is AVALABILITY)... Once more...
                            Mr. Millman is suggested because (do not want to repeat myself, few new thoughts):
                            1) did worked/lived in USA, practicing solid electronics
                            2) USA do have strong semiconductor industry (or do not have ?)
                            People which do/did work/ed in industry, did met his books (at least, if did not red them) -> so his books ARE GOOD ( in terms of simplicity to read, and accuracy of information )...
                            Actually I do not understand this reluctance toward books, especially - this book is for this, and that book is for that, books are to be used on daily basis. And with books it's possible to read one, and find that knowledge acquired will never be used (not because it's wrong or outdated, but because it's not needed)..
                            Sorry for being devil's attorney... Sorry for OFF TOPIC... I do put books before web... (Probably won't defend books for a quite some time, had to dig out few OLD books, do fast search, fast read, make long and tedious post.)
                            • MDOC
                              EngineeringTech
                              • Mar 2010
                              • 146
                              For future reference when looking at schematics, it's easy to tell an NPN from a PNP:
                              NPN = "never pointing in"
                              PNP = "Pointing in"
                              • Sus256
                                HISENSE 65E7KQ PRO - no boot
                                by Sus256
                                Hi all!
                                HISENSE 65E7KQ PRO
                                RSAG7.820.13512 - chassis
                                MT9618BAATAB - cpu
                                RSAG7.820.12059 - power
                                HD650Y3U77 - panel
                                KLM8G1GETF - emmc
                                Replaced emmc.
                                Terminal log
                                UART
                                AC_ON
                                E-B
                                FDE enabled
                                06-01-2025, 02:11 AM
                              • classicandy
                                Dell Latitude E7450 "bhtemmcdr.sys" Blue Screen error. Need Help Please
                                by classicandy
                                I have this Dell Latitude E7450 with "bhtemmcdr.sys" error that causes a blue screen few seconds after the laptop has booted to the home screen. I have attached an image of the blue screen error it shows.
                                I need help in fixing it. Thanks...
                                07-28-2022, 05:10 PM
                              • amintvn
                                precision 7730 blue screen error
                                by amintvn
                                this laptop when is installing graphic Nvidia driver, gives blue screen error.
                                i tested version driver ok.
                                could it be problem with the bios?
                                motherboard:
                                dap20 la-f601p rev:1.0
                                06-08-2023, 03:39 AM
                              • Curtissimo
                                HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                by Curtissimo
                                Hi everyone.
                                I have a HP Elitebook 850 G8.
                                Serial: 5CG2324XM0
                                ProdID 6L8D5EC#ABA
                                It has a Winbond W25Q256JVEN Chip.
                                I need to remove BIOS Password.
                                I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                Attached my dump.
                                I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                What I did:...
                                08-26-2025, 04:42 AM
                                Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
                                I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
                                One other check that...
                                08-03-2021, 06:41 PM
