Blue ESR meter - FA error code
  • Agent24
    I see dead caps
    • Oct 2007
    • 4949
    • New Zealand
    I recently pulled apart an Apple PSU and was going to start checking capacitors when I performed a self-test with my Blue ESR meter.
    Instead of the correct .8.8 result I got an FA error.
    The manual seems to suggest that a FA error would normally be accompanied by the meter "behaving strangely" and lists possible causes for some problems, but as far as I can see, the meter is still working just fine - or at least zeroing works, the calibration resistors measure correctly, there is no garbled display, the meter turns on and off correctly and the low battery warning feature operates.
    Therefore, I am not really sure where to start, considering the only apparent fault is the FA error itself.
    Trust me to get the weirdest problem!
    -David VanHorn
  • Toasty
    • Jul 2007
    • 4171
    Re: Blue ESR meter - FA error code
    >>Trust me to get the weirdest problem!<<
    lol
    I'm sure Bob Parker will see this, but if he does not, send him a PM asking him to respond.
    veritas odium parit
    • Bob Parker
      Technician
      • Feb 2007
      • 182
      Did you follow all of these pre-self-test checks in the manual:
      Before doing the self-test, it's very important to first set VR1 to the center of its adjustment range, short out R30, 100R and make sure that the meter's supply voltage is in the range of 6.2 - 6.8V.
      It is a good shrubbery. I like the laurels particularly...
      • Agent24
        I see dead caps
        • Oct 2007
        • 4949
        • New Zealand
        And just like that the "problem" is solved. On testing it now shows .8.8 as it should.
        I remembered that it needed to be run from a lower voltage for testing, and checked this in the manual but somehow completely overlooked the detail about the resistors...
        Thanks for pointing that out. Hopefully I will get it right the next time!
        -David VanHorn
        • Bob Parker
          Technician
          • Feb 2007
          • 182
          There were some changes made in the Blue meter to minimise damage if it was connected to a charged high voltage capacitor. The addition of R30 was one of them. Unfortunately it caused the 'FA' fault code to pop up in the self-test function.
          I didn't change the firmware to get around it, because then there'd be confusion about which version suited the Dick Smith meters and which version was for the Blue meter.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4949
            • New Zealand
            Ah, I didn't know that it had been changed like that.
            I guess that makes sense with the addition of that resistor when you look at what the FA code is supposed to alert to.
            -David VanHorn
            • Dannyx
              Hilti PD30 Laser Range meter Error 276
              by Dannyx
              Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
              So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
              07-30-2023, 05:05 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              The TV does not turn on, the standby indicator is on. All voltages are present.
              Emms is dead. Not readable, not detected.
              Replaced emmc.
              But with another dump there is no launch
              Terminal log
              UART
              AC_ON
              RPMB key is not yet programmed
              HASH1_VERSION=0x00000000 64bit
              E-B
              FDE enabled
              layout pattern onebin by SAR7,0...
              06-01-2025, 02:11 AM
            • classicandy
              Dell Latitude E7450 "bhtemmcdr.sys" Blue Screen error. Need Help Please
              by classicandy
              I have this Dell Latitude E7450 with "bhtemmcdr.sys" error that causes a blue screen few seconds after the laptop has booted to the home screen. I have attached an image of the blue screen error it shows.
              I need help in fixing it. Thanks...
              07-28-2022, 05:10 PM
            • amintvn
              precision 7730 blue screen error
              by amintvn
              this laptop when is installing graphic Nvidia driver, gives blue screen error.
              i tested version driver ok.
              could it be problem with the bios?
              motherboard:
              dap20 la-f601p rev:1.0
              06-08-2023, 03:39 AM
            • Maalobs
              Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
              by Maalobs
              I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
              The relevant service manual for the chassis is available here.
              The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
              When I short the SDM to ground I get the layer-2 error code 53.
              The inside of the TV has no damaged components and no swollen capacitors.
              In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
              04-02-2019, 01:15 PM
