Question to other AADE LC meter owners
  • SmallWalrus
    • Jan 2012
    I have just ordered for myself a kit for AADE's LC meter, and was reading through the instruction manual to get a hang of what's involved to get it together.
    One thing I noticed as I was going through the parts list is that the design consisted of a pair of 2 capacitors, C2a and C2b, of which the total capacitance is vital to the operation of this thing.
    I was actually considering swopping the capacitors out for some higher quality ones Wimas, but I guess I won't be able to do it now.
    I don't like a tool that I don't understand how it works, it seems like the meter will potentially go "off" calibration after some time (http://www.cliftonlaboratories.com/a...ter_review.htm), and since I am assuming Neil is also a fairly old gentleman, it might leave me with a meter that I am unable to troubleshoot or recalibrate in the future!
    Does anyone know the mystery behind the values of C2a and C2b? How are their values determined?
  • proxneo
    Recapping Sony ICF-SW55 - verifying cap values
    by proxneo
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which...
    06-21-2023, 12:38 AM
  • chth96
    by chth96
    03-09-2024, 10:03 PM
    12-31-2023, 06:04 AM
  • rashidjafar
    Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
    by rashidjafar
    I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
    Values for :-
    PC43 : Capacitor [3x1.5mm]
    PL7 : Inductor [2x1mm]
    PC39 : Capacitor [1x0.5mm]
    Any ideas would be appreciated.
    I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
    08-07-2025, 05:10 PM
  • jorpec
    by jorpec
    Hi
    Thnaks
    01-23-2023, 10:37 AM
