Crosley C26HDGB ??????
  • Peter9DO
    • Dec 2011
    • 277
    So, I have this Crosley TV here that isn't working. If you look around for anything that has to do with Crosley for TVs, you will quickly see there is nothing available as for information or parts for that matter. Does anyone have or know where I would be able to find a service manual or parts for this TV.
    Thanks,
    Peter
  • Bob Parker
    Technician
    • Feb 2007
    • 182
    Re: Crosley C26HDGB ??????
    Thanks,
    Peter
    Hi Peter,
    You could try putting your question to a large number of electronic repair people on the sci.electronics.repair newsgroup. That's probably your best hope of getting the info you need. Good luck.
    It is a good shrubbery. I like the laurels particularly...
    • Peter9DO
      • Dec 2011
      • 277
      Okay, thanks for the help!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        or post it in the proper forum here with good pics of the boards.might be a well known rebadge.
        https://www.badcaps.net/forum/forumdisplay.php?f=31
        • Peter9DO
          • Dec 2011
          • 277
          Ooops! Just noticed I posted it in the wrong forum... Thanks for pointing it out.
          • db7am
            • Feb 2012
            hi peter
            i have this same tv with the same problem
            what ended up fixing it?
            thanks!
            db
            • Peter9DO
              • Dec 2011
              • 277
              No clue my friend, I can't find parts for this thing. I was going to replace the main board but they are just not available ANYWHERE! I just put this one on the back burner for now. I truly think it's the processor on it, but it's all on one board and as I said, you just can't find the parts anywhere.
              • Mark D
                Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                by Mark D
                The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                10-29-2024, 03:15 PM
              • 2elw
                SVOD4 PCB pictures + parts
                by 2elw
                Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                GW1N-UV9UG169C6/I5 FPGA - Its a...
                07-04-2025, 12:23 PM
              • SurrealMustard
                What parts can be salvaged from a plasma with a damaged display panel?
                by SurrealMustard
                I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                03-09-2025, 08:29 PM
              • DynaxSC
                Asus Rog Strix B360-I Gaming - Parts Identification
                by DynaxSC
                I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
                I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
                Thanks in advance...
                08-23-2023, 07:56 AM
              • lorins_core
                BQ24800 to can it be replaced with these parts BQ24780S
                by lorins_core
                Hello to all.
                may I have a question about these Semiconductor parts BQ24800RUYR? can it be replaced with these parts BQ24780SRUYR?
                I need some good advice and also some information about it. thank you and God Bless...
                05-10-2024, 07:56 PM
