Test equipment having digital displays and no CPU control
  • japlytic
    • Oct 2005
    • 2086
    When I was investigating the National Panasonic VP-8177A signal generator (with digital frequency and option displays), I was suprised that it had no microprocessor control, but it did have a battery-backed Intel 5101L 256*4 bit SRAM (separate input and output buses) for memory (I devised a simple 3-chip circuit with commonly available ICs to make it work with a modern bidirectional bus SRAM).
    Another example of test equipment with digital displays without microprocessor control include a 600MHz frequency counter (1984 ARRL article).
    I've seen video arcade machines without microprocessor control (discrete logic, no CPU or PLDs including ROMs) from the early 70s, most notably Atari's Pong.
    I am curious, but are there oscilloscopes with on-screen character displays without microprocessor control, or even digital voltmeters without microprocessor control?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4940
    • New Zealand
    Re: Test equipment having digital displays and no CPU control
    No idea, but you can make a game of pong without a microcontroller of any sort:
    http://www.electronixandmore.com/pro...ong/index.html
    Edit: I should learn to READ.
    -David VanHorn
    • hardwareguy
      • Jun 2006
      • 405
      Some of the big benchtop DMMs from the early 70s using nixie tubes likely have discrete logic.
      I need to take apart that big HP DMM at my friends lab....it's so ancient that it uses 7 segment displays that use multiple LEDs per segment as the LEDs at the time weren't bright enough to allow one LED to light an entire segment. It was probably an obscenely expensive instrument.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4940
        • New Zealand
        The capacitance meter I built runs all on standard logic ICs, with a 4-digit display using 7-segment LEDs
        I posted the design here somewhere... (it's from 1990!)
        -David VanHorn
          Most digital multimeters these days don't use a microcontroller, they have an ASIC/ASSP chip which integrates an ADC and display driver. Even the fancy features like frequency counters and cap testing are done entirely in logic, although on one piece of silicon.
          • Longbow
            • Jun 2011
            • 623
            Not everything needs to be controlled by a CPU. ASIC's are more practical and faster for specific applications. Why would a freq. counter need a CPU? All it needs is a stable reference oscillator, a counter and a display. The simpler the design, the more likely you can fix it when it breaks.
            Is it plugged in?
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
              FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
              BOOST CONVERT CONTROL IC
              The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
              FP5139 FEATURES...
              10-07-2024, 05:15 AM
            • Yanleb
              LG 60PK550 Logic Control Board EBR63450301
              by Yanleb
              Hi all, I just want to share the repair of my 60PK550-UA TV set.
              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
              C57: 3.30V
              C61:...
              07-20-2023, 12:38 AM
            • harp
              triac phase control 0-100%
              by harp
              Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
              06-02-2024, 09:00 AM
            • Topcat
              Digital Equipment Corp (DEC) Starion 919 Restoration
              by Topcat
              Someone dumped this off on me yesterday; said it's been in their basement over 20yrs and wanted it gone (along with a few other older PC's, but this one was the true relic). The fella said it stopped booting back in the late 90's, and it's been in the basement since.
              Two issues I found that were booting killers for it; the Dallas RTC is bad (won't hold BIOS settings, but will keep the time/date...go figure) and the 1.2gb Quantum Fireball (furball) is bad (spins up, seems ok....and then out of the blue will spin down). The floppy is flaky (struggling to read; even after cleaning),...
              10-20-2021, 07:49 PM
