Recoating a Tip?
+ More Options
Posts
  • bigbeark
    • Jan 2010
    • 661
    Recoating a Tip?
    I have a Hakko 936 with a 2.4mm chisel tip taht I use for recapping.
    I have managed to "clean off" the iron coating, so now you see the copper underneath.
    I coat the tip with solder, but it doesn't stay. If I use tip cleaner I still have to repeatedly re-tin the tip.
    My idea is to use a solder with a higher melting point - say silver solder to tin the tip.
    Then when I am using the regular stuff, the tip will stay tinned.
    Any comments?
  • jsog
    • Feb 2011
    • 220
    Re: Recoating a Tip?
    There's tip tinner.
    • Toasty
      • Jul 2007
      • 4171
      A "real" silver solder is usually an acid-based core. Not good for tips. Fine for metalwork and torch. The electronics solders with silver in them are rosin core, but there is no gain to tip longevity, only joint strength.
      Your best bet is to keep spare tips handy and replace them when you reach the point you are at now.
      I remember when Radio Shack introduced the iron coated tips for their irons 30+ years ago. What a god-send!
      veritas odium parit
      • Krankshaft
        • Jan 2007
        • 2328
        Radioshack still sells the crappy copper tips for their higher wattage irons last time I checked anyone who still uses their crap must go through tips quickly.
        • smason
          • 1652
          I dunno. $2.59 on Ebay for a new tip, seems like a no-brainer to me.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            True. But i've never had to replace a tip in my life... altho i still have plenty of time ahead. My 25W iron belonged to my grandfather. It's made in Russia and it's over 20 years old IIRC. It came with a big round copper bar for a tip. When it gets dirty, it can be cleaned using sandpaper. When i need to solder SMDs, i can sand it till the tip gets sharp enough for what i want to solder. Then when the tip has gotten short due to all that sanding, i can simply loosen a screw and pull more of the bar out. It has enough to last another 10 years.
            A working TV? How boring!
            • mathog
              • Mar 2010
              • 2655
              If you really want to you could probably electroplate iron onto it. Oh heck, somebody else must have thought of that and tried it already. Googling... Yup, it can be done, here's a link:
              http://www.finishing.com/379/18.shtml
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                the desoldering irons are the worst... 45w and the tips of the tips are thin... but when you have no $ for a hakko 808, you use what you can get.
                sigpic
                (Insert witty quote here)
                • Toasty
                  • Jul 2007
                  • 4171
                  Neat stuff!
                  But, that's a lot of work (and some really nasty chemicals) for a <$5 tip.
                  I'm with smason on this one.
                  veritas odium parit
                  • smason
                    • 1652
                    Un1qu3, I suspect my Weller is older than you by a few years
                    I've only replaced the tip on my Weller once in 30some years, and that was because the temp sensor got flakey, the tip itself still looked great.
                    I only replaced the one on my Hakko (which I got free) because it was too big. I did have to replace the element, but it had sat powered on 8 hours a day for years in the shop that I got it from.
                    That said, if I "cleaned" the plating off of a tip, I'd just replace it.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Could very well be. Btw, scratch that 20 years about my iron... it's likely more than 30 years old. As i grow up i forgot to restate the age of some of my tools... a habit i guess.
                      As for me, i'm gonna be 20 next month.
                      • smason
                        • 1652
                        Jeez, most of my test gear and tools are older than you.
                        Feeling old now, pass the Geritol.
                        • ChaoZ
                          • Oct 2007
                          • 37
                          I've used an Antex copper pointed tip, for my 230v mains soldering iron. It's good quality but it disintegrate itself after every use.
                          *BLAH* After 6 months and it is gone. my $$$.
                          On the other hand, the tip refresher/activator/tinner is as expensive as a new tip.
                          • Digital Technophile
                            revrse engineer
                            • May 2011
                            • 144
                            Originally posted by jsog
                            There's tip tinner.
                            Thanks for the "tip"
                            Hey now smason, you're only as old as you feel; got any Geritol left?
                            Man, that means you were born when I was in 10th grade!!! Seriously, I'd love to be 20 (hmmm, make that 21) again! Enjoy your twenties Th3_uN1Qu3, we're coming over there to kick your ass if you don't
                            If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              I remember our old shop manager sanding down regular tips with sandpaper
                              and our new manager saying he'll replace caps with a pen torch
                              I work with a bunch of idiots
                              and he says he might visit here, so yes TERRY i'm talking about you
                              • Evil Lurker
                                Warranty Voider
                                • Feb 2011
                                • 454
                                Im a cheap bastard and use harbor freight soldering irons. If I catch them on sale I can get them for less than $4 each. Use my glas-col heating mantle controller to regulate their heat if need be. When a tip gets too fu-barred I just take and rub it on a fine bastard file until it has a nice sharp tip on it. Then immediately retin it before it has a chance to oxidize.
                                I know this isn't "good form" but it works in the end. The irons themselves will run a looong time plugged in before they die, and you can do a lot of filing on a tip before it wears out. When it goes, I just buy a new iron.
                                Radio shack desoldering irons are total crap. I do good to get one to run for 12 hours or so before they die. My current desoldering iron uses the same pumping mechanism, but the tip has been replaced with a heavy copper gas torch tip modded to screw in where the dinky stocker went. For heat I filed the shaft that goes into the iron down to where it will fit in a harbor freight iron, and provide supplimental heat via a bunsen burner. Needless to say it will handle joints soldered with that RoHS bullshit in an instant... ya know the kind where you can literally set the PCB on fire and the joint still remains solid.
                                I plan on kludging some sort of heat reservoir onto a harbor freight iron, adding on a grounding strap, and modding a foot switch to momentarily turn the iron off when working on sensistive stuff. Pick up iron, push on foot pedal right before you solder the joint, and use the heat stored in the reservoir to get the job finished.
                                • corrize
                                  Best way to solder LVDS connector for beginner (and qfn) ?
                                  by corrize
                                  Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                  I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                  I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                  See the test :
                                  https://youtu.be/bNAzC-EvqHs?t=1767
                                  With hot air from bellow the board, that's...
                                  03-09-2023, 02:57 AM
                                • myth77
                                  UV solder mask - high temp resistent, recomendation?
                                  by myth77
                                  Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                  Is there any solder mask...
                                  03-28-2022, 04:04 AM
                                • petemanuk
                                  BGA solder balls not connecting - help pls
                                  by petemanuk
                                  So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                  I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                  I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                  11-16-2022, 05:21 AM
                                • corrize
                                  Soldering qfn problem ; it don’t go flat
                                  by corrize
                                  Hello, I tryed to solder 3 qfn chips recently, and same problem : I press it hard and the chip stay in the air, there is a quarter of millimeter between board and chip, I don't see the sides pads of chip soldered to board and I guess the chip is not properly soldered (not tested).
                                  I tryed with qfn 20 and 28, the same.
                                  I start to solder with board pads tinned (lead solder wire), I place the chip without flux under but I put a little bit of flux at two sides of the chip to hold it in place.
                                  After solder, I reflow (400 degree) while pressing chip, two times at...
                                  04-17-2023, 02:54 AM
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
