Benchtop Power Supply Question
  • JC173
    • Dec 2022
    • 9
    Hey all,
    Relatively new to the hobby, and I'm looking to purchase a benchtop power supply unit.
    I'm looking at this range of units, but I don't understand what voltage and amp range I should shoot for. Also, why would the 120v unit only produce 3 amps?
    https://amzn.to/3ZiQqvd
    • 31612
    Re: Benchtop Power Supply Question
    cant answer the question unless we know what you want it for.
    maybe you only need 30v - maybe you need upto 200
    maybe you only need 3A - maybe you need 60A
    it all depends on your use of it.
    • JC173
      • Dec 2022
      • 9
      That's a fair point
      Point is I'm not really sure what I need. I intend to do mainly smaller projects, but I want to test salvaged circuits or LED strips at the moment.
        • 31612
        led strips from tv's = pretty high voltage
        • JC173
          • Dec 2022
          • 9
          Somewhere between 27 and 29 volt given the ones I have now. It's roughly 3.3v per LED right?
            • 31612
            no,
            the leds often have multiple chips in them and the strips use around 80v
            • JC173
              • Dec 2022
              • 9
              no,
              Reeeally... how do I know if there are multiple chips?
              Would the 120V supply be adequate given that it only supplies 3A?
                • 31612
                look for info in the tv section
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8762
                  • Fixing Failed Fuhjyyus
                  A TV that uses 120V to power LED strips at 3A would mean it's a very big TV since it means it's drawing 360W, that's very very bright, my 40" LED TV is less than 60W...
                  And it's a switching PSU, it's wattage limited - more volts means less amps.
                  I wouldn't trust a 120V switching PSU for low voltages...so if you really need low voltages more than high voltages, I'd stay away from it especially if you need more current.
                  Again back to what you are going to do with it... and one size won't fit all.
                  • UNITRAX
                    • Jan 2023
                    • 64
                    • POLAND
                    • Audio HIFI, Wood Sculpture, History
                    Maybe it's worth mentioning about basic security, when talking about power supplies?
                    What current protection devices do you use in your workshops?
                    https://www.youtube.com/watch?v=wRFRwOnLsZI&t=1s
                    Great simple thing.
                    • JC173
                      • Dec 2022
                      • 9
                      The problem is, I don't know enough about the hobby yet to know exactly what I need or what I might end up using it for.
                      Great simple thing.
                      I'm working on building one right now actually
                        master hoarder
                        • May 2008
                        • 12182
                        • Fixing stuff
                        I'd say if you're just starting with learning electronics, 0-30V and up to 5-6 Amps should cover plenty of ground. If you plan on doing experiments with many "heavy duty" DC motors (i.e. anything size 540 and up), consider dropping the voltage requirement a little (down to 24V, perhaps) to get more current: 10-15A for such motors. Even then, that might not be too cheap, considering 10 Amps at 24V is already a 240 Watt PSU, and that can be expensive.
                        IMO, best way is to get several different PSUs, and not necessarily bench type. In fact, I *still* don't have a (working) bench PSU, despite experimenting with projects quite often. Majority of small breadboard projects I power with small plug-in power adapters (5V, 9V, 12V, 15V, etc.) And when I need more heavy current with low voltage, that's where my ATX PSUs come in. For higher voltage, I've used various contraptions - from non-isolated resistive mains droppers (light bulbs, soldering irons, countertop ovens, and etc.) to AC dimmer-controlled transformers.
                        It's certainly more cumbersome to do it my way, but it's also been cheaper (and I find it more rewarding, since I sometimes have to *actively* think about how I want to power something, rather than just dial in a number on a bench PSU and hope it all works fine.)
                        That said, there have been times where I did wish I bought or made an adjustable PSU. Most of these were when I needed low voltages (3.3V or less) at medium to high currents (more than 2-3 Amps) and good regulation. But again, I think 0-24V or 0-30V @ up to 3-5 Amps should work well enough for you to get into electronics. That along with a computer ATX PSU and a 60-90 Watt 19-20V laptop adapter should cover a good deal of projects.
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          Right to the point !! ... I have all kinds and for all purposes . Lately , I had to repair a car stereo at home . I needed something 12v with powerful amperage . 10 minutes of thinking and opening whole boxes and then I grabbed an old computer PSU which did the job fairly well . When I finished the repair and On testing CD's , i had to limit the sound volume to not more than 50% , or else , the PSU would cut off .
                          Yet , In a room , I have like 5 or six laptops on a one huge table , and I've got sick of adapters and cables , inlets and outlets , so I decided to build one powerful unit to replace all the adapters . I'm now checking my old electronic schematics to choose the convenient one .
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            I use my 30v 3A power supply for the majority of my power supply use.
                            I have a device for injecting low voltage and high current for help with detecting shorts and I have a 900W boost converter for the occasions I need more than 30V.
                              • Jul 2011
                              • 6083
                              • Soldering Junkie
                              I want to know how you did this when some laptop computer switching power supply have a third wire on the outside a lot of them will not work with out it
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                I didn't do it yet , and if you continued reading the whole post ,you would know that ..I'm still searching my old schematics .
                                Do you mean the Ground wire as the third wire ?
                                  master hoarder
                                  • May 2008
                                  • 12182
                                  • Fixing stuff
                                  Sounds like an interesting project. I suppose just one big 19-20V PSU to power it all with lots of laptop plugs. The only thing is, you have to make sure each output is current-limited to what a regular laptop power adapter would normally be (60-90W, typically, aside from a few high-end / gaming machines.) Otherwise, you may get some "interesting" fireworks, should a laptop go faulty with shorted silicon somewhere.
                                  Also sam_x3 brings a valid point about the 3rd / ID wire. Don't know how Dell and HP are these days, but a few years back and more, Dell were still very picky about having a genuine adapter. Can't tell you how many I've seen with dead / discharged batteries or running in low performance because the ID wire on the original adapter went bad at some point and so made the laptop perform in lowest state and/or not charge battery.
                                  • jiroy
                                    • Jun 2016
                                    • 2416
                                    • Lebanon
                                    Ah , okay ..The DC third wire of Hp and Compaq mostly ..Well , if you remember Momaka , some years ago , I talked about my loss (app. 5000$) when I bought some laptops affected with the Nvidia problem . I talked also about how they refused to fund money back , and instead , to grow my frustration , they offered cheap compaq something with no Nvidia inside . I thought back then , what da hell , the rotating and touch screens of my Hps were more expensive than their offer .. In other words , another treachery .
                                    Eventually , I stopped buying ANY HPs ! . Same recommendations to friends and customers ..
                                    Right now , I have only Asus (Republic of games,770GTX 16GB) as primary set , and 3 Acers Icore 3 , one mini Asus for nightly purposes and one Toshiba 8GB DDR2 (Yes , believe it or not , unique ,and needs more posts later), so basically i'm in no need to a third wire .
                                    By the way , i laughed at (Sam x3) , lol ..
                                      • 31612
                                      we can fake the 1wire eeprom with an arduino or a pic to fool those laptops
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Yes, Dell still does this, and it detects the wattage of the connected supply. Aftermarket power supplies can fake it, so they don't need to be genuine.
                                        Thing is, if for any reason it can't detect the wattage, it'll totally nerf your laptop. Either it won't charge the battery, or your CPU will be stuck at some stupid low clock speed and the computer will be unusable.
                                          03-31-2024, 02:12 PM
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • Gjackson
                                          Air-conditioning unit power supply failing to power up
                                          by Gjackson
                                          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                          01-08-2022, 09:24 AM
