Remove CMOS battery? Does it matter?
  • SheDevil
    • Oct 2005
    • 8
    I removed all other parts, but did not even think about the little battery there before I started the de-soldering. As I get to the 3rd to the last smaller crap, I noticed it is by the battery.
    Should I have removed it? In not doing so will that damage something?
    Can I test the caps with a digital volt meter that reads megohms to .001? Some are above that, but the new caps are in that range .006>.001 or does that special ESR meter do something else in testing them? The megohms on some of the swollen ones were above 3.000
    In testing the volts on the old ones I found a few that with the leads on correct + and -, it reads a negative voltage. Is that another indication that one was on its way out?
    Soltek 75DRV-5
    GSC Caps
    Enermax EG365P-VE
    next step is to look at PSU while it is torn apart.
    Thanks, hopefully another board saved.
    Shedevil
  • MD Willington
    • Sep 2004
    • 702
    Re: Remove CMOS battery? Does it matter?
    Batteries are ~$5 for a dual pack at walmart (Sony, Panasonic or Energizer CR2032)...I'd just buy a new battery...
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • Rainbow
      • Aug 2005
      • 1374
      Personally, I don't remove the battery when soldering the caps (or anything other not related to CMOS power). But I take care not to short it out (the easiest way to destroy the battery is to put the board on metal surface). I never buy new batteries as I sometimes get boards that are unrepairable but the battery is often good
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        what is the brand of multimeter, it sounds interesting.
        it would be best to check the caps when the board is working using an oscilloscope.
        can read this about esr
        http://www.repairfaq.org/sam/captest.htm
        • AK0R
          • Mar 2005
          • 204
          Shedevil
          No. Digital voltmeters measure resistance with a DC voltage. ESR is measured with an AC voltage. To truly compare apples to apples, you need to know the frequency used by the manufacturer in specifying the part. Also, .001-.006 on a 1 megohm scale equates to 1000-6000 ohms, which tells you nothing about the quality of the capacitors. ESR on good electrolytic capacitors is much less than 1 ohm.
          • Rainbow
            • Aug 2005
            • 1374
            You're basically testing the capacitance - the bad caps get charged by the meter (as they have often very decreased capacitance, not only high ESR) and so they "look" like a higher value resistor to the meter.
            I've tested this on some bad caps and meter set to 2M ohms - all caps that showed higher resistance were bad (bulged). But it does not work the other way - some were bulged but the resistance was still "OK".
            • SheDevil
              • Oct 2005
              • 8
              Thank You to all, what a task.
              I was trying to look for a way to test the new ones to double check. I DO NOT want to do this again anytime soon! coffee and soldering don't mix sometimes. good thing I am very detail oriented and have patience. I just know that sometimes even new things can be faulty.
              I suppose I could call around to see if any local tv-radio repair shop would test them for me.
              Would they be able to tell me if the new caps were all good, weed out any weak ones?
              They are Nichicon HE series I bought them from Mouser online. I got that HE series because the size matched better than the PW.
              PW 1000uf 6.3v .068 Impd 755 ripple 10x12.5mm
              HE 1000uf 6.3v .087 Impd 840 ripple 8x15mm
              I'll be ready for them to laugh at me too. One guy told me he would not do what I am doing in a million years and kind of laughed at me like I was stupid for even trying. Then what the #$%@ are your doing in the repair business I felt like saying. We repair pools and spa and I would never think of using that approach he did with me on the phone.
              So if the solder sucks down into the hole, and I have a nice shiny cone with no spikes, is that a good indication that the solder joint fills the hole to the other side? I put just a small tick of flux in the hole, does that help make a better solder joint?
              I'm using the 62/36/2, only one in the .022 size.
              I just found that when I put a little flux on the solder braid it sucked up onto the braid better.
              Shedevil
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                i dont bother testing the new ones, i just use them and if the board is not passing memory tests or stress tests then i guess i would look into testing. but it has not happened, the majority of the boards/devices are still working perfectly and the asus board i screwed up i know was due to excessive heating.
                i never did get around to getting a cheap scope like KC8 recommended and learning to use it. It is a good idea though because you are testing the circuit as it is working and seeing how the old caps/new caps are performing.
                it is not necessary to put flux in the hole, i just use 60/40 0.8mm, heat up the lead and solder pad at the same time and close the hole with solder. no need to make the solder fill the hole through to the other side, the lead port is connecting the solder pads on the front and back of the board and making the connection to the right traces in the board layers.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Maxpower3
                  Hantek 365 Remove screen on startup
                  by Maxpower3
                  every time I open the tool, I have the screen that appears
                  and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
                  It annoys me lol.
                  2 solutions to remove it.
                  Either you remove pic.bmp and it no longer appears so no more links when clicking.
                  hope this helps users...
                  01-15-2025, 03:24 PM
                • dqtech
                  lenovo thinkpad t420 wont turn on when cmos battery attached
                  by dqtech
                  please help...this lenovo thinkpad t420 early problem is short 19v...after replace short capacitor all working fine...but, when i attach cmos battery on motherboard this laptop wont turn on, power button not respond....it only work without cmos battery....power button and cmos battery is in good condition...i try replace new cmos battery but problem still persist...any idea?...
                  06-16-2023, 03:56 AM
                • EsIstSimon
                  Lenovo Ideapad 5 15ARE05 random freeze
                  by EsIstSimon
                  Hi there,
                  i have a Lenovo Ideapad 5 15ARE05 that will freeze randomly.
                  Sometimes it wont even post, sometimes i can use it for a couple seconds or minutes before it completely freezes.
                  Sometimes the screen freezes, but still displays the last frame, sometimes (pretty rare) the screen goes black
                  It does not matter what i do. Installing windows, starting Fedora or just sitting in the bios. After some time it will freeze.
                  When the freeze occurs, the laptop draws a pretty constant wattage (it will just stay on the value that it draws, when it locks...
                  12-21-2022, 03:03 AM
                • rumpumpel1
                  ThinkPad T470 does not power up with CMOS battery attached
                  by rumpumpel1
                  I have a ThinkPad T470 that will not boot when the CMOS battery is plugged in.
                  With only the fan, a RAM module and a USB-C monitor attached, but no CMOS battery, it starts up normally, i.e. after about 90 seconds and two reboots, it stops with a message to press F1 to enter date & time.
                  If the power is switched off and a CMOS battery is inserted, it restarts as described above. However, after switching it off and on again, it does not turn on. It draws almost no current and shows no sign of life.
                  I used a different CMOS battery and checked the components around the battery...
                  04-27-2023, 10:46 AM
