Samsung UN70NU6900FXZA PSU failure?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Scored a Samsung UN70NU6900FXZA curbside several days ago.
    Issue is it won't turn on and blinks the power light (red) constantly. Upon opening it up and retesting, it is flashing the backlights (they seem to be good).
    The marked standby power is reading 12.9VDC, it's supposed to be 11.5VDC. Power on is reading 0.3VDC. See attched pictures for what I'm referring to (referenced to the 0V pin on the main board cable connector). This a start? Or am I barking up the wrong tree (bad main board, etc.)?
    Last edited by ratdude747; 08-26-2021, 08:41 PM. Reason: Pics didn't upload... my bad!
    sigpic
    (Insert witty quote here)
  • Storyteller12
    • Jun 2020
    • 625
    Re: Samsung UN70NU6900FXZA PSU failure?
    Most of the nu series TVs have bad backlights.
    • RDC55
      • Dec 2017
      • 180
      And I guess many of that series also have internal damage from the LED burn.
      https://www.badcaps.net/forum/showthread.php?t=96567
      With Samsung models you should be able to test the Power Supply / Backlights by disconnecting the interconnect cable between the Main board and Power Supply. The backlights should come on when power is applied if the Power Supply and LED's are operational.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Will try when I get home from work. The back lights were coming on at times during the blinking red light routine... white and bright.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Unplugged the main board cable from the PSU, plugged in power, backlights came on and stayed on. Nice and bright.
          sigpic
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8286
            Can you post pics of all the boards? And what is your power on now?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Attached are pics.
              Cable unplugged, power on is at 0v. Still 12.95v on standby.
              sigpic
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Very sad! Looks like it was made in 2019!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • RDC55
                  • Dec 2017
                  • 180
                  Attached are pics.
                  Seems a bit odd. So the 12.95V is from the JP822 jumper to chassis ground? You stated earlier referenced to the 0V pin on main connector, which I suppose could be chassis ground but that needs to be verified. Also, if the cable is unplugged you can't be using that point of reference in this second measurement.
                  Power On 0V? With Samsung I believe all the commands should float high when the Main is disconnected. So just to be sure that Power On you are measuring is pin 8 on CNM0801 to chassis ground?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8286
                    What are the voltages on each pin on cnm801? Sounds almost like the main board has a problem turning the whole tv on… probably there is a voltage missing on one of the pins on cnm801.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Verified that the 0V pin I was using is indeed tied to chassis ground.
                      Odd thing is the power on PSU connection (the jumper link pictured in the first post) is showing up as shorted to ground... both polarities, so not just a diode. Something on the PSU board shorted out???
                      sigpic
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8286
                        disconnect the main board and force the PSU on. Then you can see what's going there.
                        • R_J
                          • Jun 2012
                          • 9579
                          In post #5 you proved the power supply is working, Pin#8 of CNM801 is power_on. it is connected to RM870 which should be the pullup resistor for the standby transistor(QM854?).
                          Check the voltage on JP819, this is the power_on line going to the base of the standby transistor and should be around 12v when the power supply is on.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            All tests since post #5 have had the main board cable unplugged from the the PSU.
                            If power_on is pulled up, then why with no cable connected is it reading 0v and coming up as a dead short to ground in both directions? Assuming this standby transistor is on the PSU, that makes me think it blew up and shorted out?
                            sigpic
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              At least 2019, if not the 2020s!
                              Arc A770 16 GB
                              • R_J
                                • Jun 2012
                                • 9579
                                Is this the BN44-01016A board? If it is, is the jumper JP819 shorted to ground?
                                Pin#8 of CNM801, connects to two resistors, RM870, which is the pullup res. and its other end connects directly to the stb:11.5v AND RM871 which connects to JP819 and then to QM854
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  That's the board number.
                                  Pulled the board. Seems I was probing the wrong thing as power on (JP811).
                                  JP819 is not shorted to ground. your description matches. After re-installing the board, JP819 is reading 4V when the mainboard cable is unplugged. Plugging the cable in (and re-applying power) puts JP819 at 3V, but it's occasionally spiking out of meter range (which corresponds with the mainboard "resetting".
                                  sigpic
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    Looks like 2019 or 2020! It wouldn't surprise me if the panel was made in 2019, but regardless, this is way too premature!
                                    Arc A770 16 GB
                                    • MikePCS
                                      • Apr 2022
                                      • 4
                                      Hello -
                                      Sorry to bump an old thread, but I have this same exact TV with identical symptoms and voltage readings
                                      my STB is 13V
                                      and my On voltage is in the 4's - same as you
                                      did you ever find a resolution to the issue?
                                      I bought this TV only 14 months ago, out of warranty and trying to salvage!
                                        09-07-2024, 05:50 AM
                                      • max789
                                        Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                        by max789
                                        Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                        I made the following tests:
                                        1. Disconnected the main board from Power Board = backlight works.
                                        2. Connected the main board and disconnected the T-Con = backlights does not work.
                                        So I ordered a main board from Ebay also BN41-02156A but from...
                                        01-18-2024, 06:56 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
