Long live thrift stores....
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I was told that the local thrift shop had a bunch of computers for sale really cheap......reluctantly I went and checked it out...... I know now why I was reluctant, there was a pile of beat to shit emachines systems and a few banged up dells, all of which was s370, socket A, and a few 478 systems, nothing too terribly recent....most all beat to hell and overpriced.
    I guess there's a white sheep hiding amongst every herd of black sheep... I walked around the shelf to the other side, low-n-behold, there's a 20" Imac sitting there, KB, mouse, and all. Sticker on it says "runs for 5 minutes then shuts down, $10.00" For 10 bucks, what the hell. I took it up front, paid and left. Sure enough, I get it home, and we all know what was ailing it.
    This one is going to be part of an experiment. Details later.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Long live thrift stores....
    if anyone can fix it you can! lucky you :jealous:
    sigpic
    (Insert witty quote here)
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      After you make it work again you know what you may need to do....LOL Cut the case all to hell and cover it with fans.
      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
      Mark Twain
      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
      John Paul Jones
      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
      Rod Serling
      • seanc
        • Nov 2008
        • 1319
        Bonus points if you explore the PSU.
        I still have a dead PSU I wasn't able to fix, here.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Yes, that's standard procedure around here. PSU gets recapped when the logic board does. I have some more G5's on the way for some experiments, which will be released later....this one was just a lucky find.... I havent recapped it yet, I'm waiting for some goodies to arrive.
          Team : 49813
          Join in!!
          Team Stats
            • 31201
            i did one of those,
            the mobo is a bitch to desolder from - i have never seen a pcb soak up heat like those!
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Originally posted by stj
              i did one of those,
              Try stuffing polymer caps with fatter leads into those tiny holes.... I've found I always have to turn up the heat on the soldering station to easily reflow the solder. It takes longer to get one apart than it does to recap it.
              Team : 49813
              Join in!!
              Team Stats
              • Colt45ws
                • Jan 2009
                • 174
                Im not a apple fan but for $10 I would've taken it too!
                • severach
                  • Aug 2007
                  • 1055
                  Yep. The Hakko 808 is able to take the caps out but is unable to clear many of the holes even with the help of an SMD heater. That's the only board yet I've needed to drill to remove the solder.
                  The new caps were soldered with tin/lead.
                  sig files are for morons
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    NEVER drill out a through hole on a multi-layer PCB!! If there's a plane in the layers connected to the tube in the through hole, and the hole is drilled out, then the contact will be destroyed, as well as the rest of the board. A good pick and a hot iron, iMac boards aren't any more difficult than anything else.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Dgtech
                      E. Technician
                      • Apr 2009
                      • 1462
                      • Steeler
                      You got me ready to do some thrift store hopping!!! I just lucked out last week when I saw an ad on CL for an oscilloscope. This guy is selling like 20 used tube O'scopes (30 Mhz) for $90 each. I glanced around the room and I saw a portable Tektronics TDS 1002 Digital storage scope and I asked him, " how much for the little one" he told me $30. LOL. It was the last portable one he had. That guy had no idea what he had. He was selling off the school's remaining electronics lab equipment.
                      Keep looking for deals, they are out there!!!
                      • severach
                        • Aug 2007
                        • 1055
                        Not only do I have the right size drills, the Apple solder quality is so poor on that board that the solder doesn't wick to the component side. This allows perfect alignment which eliminates the danger of slicing the plate through.
                        I don't drill unless I need to. I was able to clear many of the holes with my guns but a few wouldn't clear without the drill and since this board is a regular customer I wasn't going to reassemble that low quality Apple product with anything less than 100% tin lead solder.
                        Next you're going to tell me that I'm in danger of removing the plate through by using a gas torch file to clean the arc soot from laptop power jack holes.
                        • NxB
                          • Feb 2009
                          • 1595
                          Drill press with tiny bits could do it.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I'm not telling you anything, do yours the way you want, it's not my board and I really don't care. However, I've seen more than a few people destroy their board doing this, which is why I don't condone it, especially for a novice. Most of the members of this site are indeed novices when it comes to component level repair, which is why they came here in the first place. Its definitely not the recommended process to clear a through hole, especially when something as simple as a hotter iron and a cheap dentist's pick will do the same thing with zero risk.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              uuh work both sides then?
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                Or use a pick. Clears the holes in less than 3 seconds per hole, no drilling required....
                                Team : 49813
                                Join in!!
                                Team Stats
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  +1
                                  got a ton of billable hours on a irreplaceable industrial board someone tried that on.
                                  i have never seen someone as happy as the owner of that machine when i flipped the breaker and the screen lit up with the japanese comic faces.it was some custom one off machine made by hitach-seiki for a .gov contract.
                                  the moron who drilled out a bunch of holes not only got fired but i bet he also got the bill.
                                  he made a real mess of that board!
