Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 06-10-2021, 09:13 AM   #1
dicky96
Sun Seeker
dicky96's Avatar
City & State: Sunny Gran Canaria
My Country: Spain
Line Voltage: 220V 50Hz
Default Can someone recommend a preheater for large boards (up to ATX size)
Hi guys
I have a semi-auto BGA rework station already but I've been playing around with cheaper options on my YT channel
I'm currently looking for a preheater suitably large enough for ATX motherboards to use with my Quick 861DW
I had a look on aliexpress and this one keeps coming up
https://www.aliexpress.com/item/1005...archweb201603_
Says it is 1600W and seems to be about big enough but I couldn't find any reviews to see if they are actually a usable piece of kit or not. Does anyone have one of these, something similar, or other suggestions
Follow me on YouTube
Learn Electronics Repair
dicky96 is offline   Reply With Quote
Old 06-10-2021, 06:29 PM   #2
megaraider
City & State: Porto
My Country: Portugal
I'm a: Hobbyist Tech
Default Re: Can someone recommend a preheater for large boards (up to ATX size)
I'm not the best adviser on this subject...
That being established, the major short come will be the actual preheated plat size 260x240.
ATX motherboards usually take up to 300 cm or more in length. Although not all the the motherboard area needs preheating, the motherboard itself takes it space to seat.
It's also over rated in power, nothing new, at full power draws 1200W.
See consumer reviews here.
megaraider is offline   Reply With Quote
Old 06-13-2021, 03:24 PM   #3
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
Thanks megaraider - well it seems it has 5 out of 5 star rating so it may not be junk
I accept an ATX motherboard is a bit larger than 260x240 but that does seem to a reasonably big heater size
I was trying to put together some YT videos which determine how to do difficult things such as change a LGA socket using the minimum possible cost of equipment so that this sort of repair is accessible to more hobbyist repairers
Yeah I can put it on my €3500 BGA station but that isn't the point of what I was trying to do, I wanted to prove if it is possible with for example a Quick 861DW, or similar, and a preheater - say 200-300 euros worth in total, as that is much more in the range of availabliity for a lot of people who may have the skills but not the finance.
In the two attempts I made so far
This one I published https://www.youtube.com/watch?v=x9Xiv19Kx-8 if you watch you will see it was not successful
And the other video I didn't upload yet (Asrock H97M), it appears to confirm that the problem does not seem to be getting enough heat into the job, it appears to be more to do with the distribution of heat. The one I didn't upload, I again managed to remove the LGA without ripping any 'connected' pads, but the upper surface of the PCB was uneven again, and I managed to burn tracks off the bottom of the PCB trying to resolder a new LGA even using two thermocouples to monitor things
I honestly don't know if what I am trying to achieve is actually do-able, though I suspect it probably is, but for sure it makes for some interesting experiments
Old 06-13-2021, 05:04 PM   #4
megaraider
City & State: Porto
Originally Posted by dicky96 View Post
It's still a nice result with the tools you used...! Nice effort!
I think it's doable..., but a question pops-up:
Socket desoldered with success THEN what...? Because soldering a new one will be impossible!
[Obvious correction on my previous post: "300mm" not "300cm"]
Old 06-13-2021, 07:05 PM   #5
clearchris
clearchris's Avatar
City & State: San Antonio
My Country: United States
Line Voltage: 120v 60hz / 240v 60hz
I'm a: Hardcore Geek
Most of this equipment is probably buildable with a 3d printer, a few parts and an arduino. Not commercial grade, but good for hobbyist work. I'm actually pretty surprised I haven't seen more builds out there.
Some light reseaching at hackaday yields an even cheaper and possibly quite effective solution. Do these boards you are working on have smooth undersides, or are there SMT devices under there? If it works, it's hard to beat $10.
https://hackaday.io/project/11566-ha...-smd-soldering
Kind of bothers me that the temperature isn't controllable, but 230C is pretty close to where you need to be. Might be too hot though.
clearchris is offline   Reply With Quote
Old 06-14-2021, 02:56 AM   #6
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
@megaraider
Why would soldering a new one be impossible? It's just the reverse of removing one isn't it, with the advantage of getting fresh flux under it? And the replacement sockets are cheap
Having said that I find it harder to fit replacement LGA sockets successfully on my BGA machine than I do removing them for some reason - I would have thought the same profile that removed the old one would solder the new one but I generally find not all the solder balls melt for some reason
@clearchris
That depends on the boards - some are smooth underneath and some have a handful of capacitors there - I'll check out the link, thanks
Old 06-14-2021, 12:03 PM   #7
clearchris
clearchris's Avatar
Yeah, I remember seeing that on some boards, but I haven't seen anything relatively modern, all my boards are probably 10+ years old. Everything else is a laptop, and those are definitely packed, both sides.
I have seen people use a salt or sand bed with a board heater. Not sure how well that works, but I may try it before going with an infrared system.
Old 06-15-2021, 02:41 PM   #8
megaraider
City & State: Porto
@megaraider
My comment never meant to depreciate, no way.
Just wondered if one can use the hot air flow gun to solder the new socket since the plastic / compound material on the socket will melt...
Old 06-16-2021, 02:34 AM   #9
dicky96
Sun Seeker
dicky96's Avatar
My Country: Spain
Yeah I see what you mean. Obviously the socket has a maximum temperature it can withstand. On my BGA machine it has IR peheater plus upper and lower hot air - so really it is just like using a hot air gun to solder the replacememt socket
Obviously that has profiles to ensure the new socket doesn't melt. But if you program a profile wrong then you *will* melt the socket and/or burn the board. I've done it once myself using that machine to replace an LGA. And I've trashed a few BGA chips too
My current thinking is, if you can get the board warm enough using a preheater below it, and in a fairly even fashion - then the fact your hot air station is not heating the socket evenly while resoldering is less relevant as you don't need to apply much more heat to 'push it over the edge' and liquify the solder balls. But this is all conjecture of course at the moment
Badcaps.net Technical Forums 2003 - 2021
